Anybody have a Circuit Sports Strut bar on a coupe?
Old Apr 24, 2009 | 04:41 PM
PTownG's Avatar
Does it hit the hoodliner?
I tried an NRG bar and it bulged my hood even at the lowest possible adjustment. It also had way too much flex to be effective.
I need a bar that is not going to hit and I am not taking my hoodliner off.
http://www.phase2motortrend.com/cispalfrstba.html
Old Apr 24, 2009 | 05:40 PM
redlude97's Avatar
I have one. It rubs the hood liner but doesn't bulge the hood as far as I can tell. It sits right above the OEM engine cover. It didn't make a huge difference in peformance after installing it.
Old Apr 24, 2009 | 06:22 PM
PTownG's Avatar
This is getting frustrating. Why do they make bars that sit so high? The NRG bar was ridiculous. There was a good 2" between the plenum and bottom of the bar. I don't need the space.
As far as I have researched the only ones that don't hit are the kinetix which is discontinued, the VRT/RA which seems to be having bracket issues and questionable availability and the stillen which i'd rather avoid.
Am I missing any?
Old Apr 24, 2009 | 06:33 PM
redlude97's Avatar
they all have a tendency to rub because there just isn't a lot of room above the plenum
Old Apr 24, 2009 | 06:38 PM
Jeff92se's Avatar
Red Card Crew
Am I missing any?
I like my NRG bar. It ever so slightly rubs but all it does is leave a polished mark on the bar. They designed that bar so it would clear the various spacers and plenums. It clears my Crawford V5 easy and still clears my hood (just touches the liner a bit)
Old Apr 24, 2009 | 09:47 PM
PTownG's Avatar
Mine pushed the hood up enough to leave a noticable gap between hood and fender. Not acceptable. Also the ease in which I was able to put weight on it and make it flex tells me it is far more a visual add than a functional one.
Old Apr 25, 2009 | 01:08 PM
idrive_MD's Avatar
I too have the circuit sports STB, it makes contact with the liner and the engine cover. It does not lift or bulge my hood.
I like it, I figure its better than not having one at all.
Also they have all that space between the plenum and the bar because plenum spacers are a commonly installed item on the Z and G nowadays.
Old Jul 4, 2009 | 09:52 PM
PTownG's Avatar
which is why the brackets on many are slotted and not just holes so it can be adjusted up if necessary. Unfortunately with the NRG bar even at it's lowest setting I could still get my whole hand between the bar and the plenum. No bueno.
Hasanbaloch
Feb 29, 2024 08:45 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
itschuckster
Jul 25, 2015 08:07 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:23 PM
justgotg35
Jul 19, 2015 12:33 PM
