Removing Caliper from Rotor - How?
Old May 6, 2009 | 12:26 AM
RiCeBrNr's Avatar
To make a small story short, I was replacing my wheel studs and started off by removing the wheel and then the two 19MM bolts behind the caliper.
The caliper did not come off the rotor and is still attached......how do I seperate it from the rotor?
The reason I need to because for some reason once I placed the rotor back onto the hub the two holes where the 19MM were don't seem to line up, they are slightly off...........
I know it seems pretty noob, but this is my first time other than doing oil changes/tires......
BTW Its an 03 g35c brembo
Thanks guys
Old May 6, 2009 | 01:55 AM
teamspink20's Avatar
put a big flathead screw driver between the pads and the rotor like on top of the rotor and pry. it sounds like the pads are just tight of the rotor.
Old May 6, 2009 | 03:04 AM
ttrank's Avatar
Grocery getter
May need to bleed the caliper a little bit.
Old May 6, 2009 | 04:06 PM
RiCeBrNr's Avatar
I used a rubber mallet and slightly tapped the caliper and it came off, it seems it wasn't the breakpads compressing against the rotor but actually the brake line.........the brake line going to my brembos is a steel brake line that has absolutely no give(very strong) and no slack either............perhaps the previous owner changed it out?
If I disconnect this line from the caliper brake fluid would seep out right?
Perhaps some more hits with the hammer, this frigging thing wont budge..
Old May 6, 2009 | 04:34 PM
uf20wop's Avatar
no that's how the brembos are set up
you need to unscrew the lines and then bleed the brakes afterward
i don't know why they designed it this way
Old May 6, 2009 | 04:35 PM
uf20wop's Avatar
you might be able to unbolt the little interchange piece where the normal brake like comes in and the solid line leaves to the caliper from the spindle
Old May 6, 2009 | 07:43 PM
RiCeBrNr's Avatar
Thanks for the tip. This interchange piece you speak of is what holds the brake line to the chasis?
I got it to line up by pushing the caliper a bit but I don't think its lined up properly because the two 19mm bolts were VERY hard to tighten.......
If I opt to disconnect the steel line from the caliper will I have to bleed just that caliper or all of them? Also, will there be fluid actively flowing through that tube? Will I need to have brake fluid on hand to top up the reservoir?
Old May 7, 2009 | 05:41 PM
RiCeBrNr's Avatar
How hard should it be to tighten these bolts? They just wont seem to budge.......I'm worried that the aren't aligned perfectly, how hard was it for you guys to tighten these bolts?
Old May 7, 2009 | 10:58 PM
RiCeBrNr's Avatar
So I finally got everything put back together but when I drove the vehicle I found that the brake pedal required alot of travel as if there was air in the system.
I didn't remove the brake line or unscrew it from the caliper.........any idea what would cause this?
I'll take it to the stealership to be bled, don't want to mess with the brakes.
seagrasser
May 3, 2022 09:43 AM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
5150DS
Sep 26, 2015 07:47 PM
TNRocker
Sep 21, 2015 08:36 AM
NJ6MT
Sep 10, 2015 08:40 AM
