Caliper question
May 13, 2009 | 06:05 AM
Has anybody ever had to buy new rear calipers, I have searched this forum
for 30 minutes and can't find anything...2003 sedan non-brembo over 100,000
miles...
GBoy
Reply 0
May 13, 2009 | 08:28 AM
and what kind of grease goes on the slider bolts..
Thanks
Reply 0
May 13, 2009 | 08:39 AM
You can buy the grease at any auto parts store. Also, you should be able to buy a rebuild kit for your caliper.
Reply 0
May 13, 2009 | 09:02 AM
Are they expense, so my guess it comes with all the parts and I keep
original caliper just swap out the small parts...
Thanks
Reply 0
May 13, 2009 | 01:52 PM
Yes, you can just overhaul your calipers, much cheaper than buying new ones. Did one of them seize on you? What problems are you having?
Reply 0
May 13, 2009 | 09:40 PM
I recently had one rear caliber seize up on my G, which has 107,000 miles. I found a great deal on the forums for two used calibers for cheap with low miles. I would agree to just buy a new caliber and try looking on the forums like I did.
Reply 0
May 14, 2009 | 03:39 PM
Guess it started 15 months ago when we changed just the pads
could not get the lower slide pin off, rusted, not right tools, whatever
but we were able to get the pads on, and we did not grease the one slider
we did get off, so now its worse, more rust and worn, so I'm going to replace
the calipers with rebuilt ones for 75$ each, so everything will be brand spanking new, the problem is they were put on dry so from now on
I will service them once a year to make sure everything is working correctly
What kind of grease should I put on the slider pins, is it called caliper grease?
GBoy
Reply 0
