True Rear Coilover VS Oem Style Coilover
Old May 14, 2009 | 07:06 PM
Dubi2087's Avatar
Hey guys, I was just wondering what the PROS and CONS are between True rear coilover and Oem Style Coilover.
I have searched and didn't find anything.
Thanks for your help...
Old May 14, 2009 | 08:18 PM
jdmgee35's Avatar
what the heck's a rear or oem coilover??
Old May 14, 2009 | 08:49 PM
Glex25's Avatar
Administrator
True rear coilover is when you have the spring on the shock body
OEM Coilovers are aftermarket coilovers that keep the spring and shock body seperate OEM style.
I prefer seperate since there is a train of thought that the shock mounting location was not meant to support the strain of the springs compressing and uncompressing. It has also been said that the bearing where the shock mounts might be weak and wear out before their lifespan.
Old May 14, 2009 | 08:58 PM
PTownG's Avatar
how does the oem set up qualify as a coilover at all?
Old May 14, 2009 | 08:59 PM
Mustang5L5's Avatar
Then they are technically not coil overs. They are just springs and shocks.
Old May 14, 2009 | 11:11 PM
Glex25's Avatar
Administrator
They are still coilover since you can adjust height and preload separately apart from dampening in most.
Old May 15, 2009 | 08:13 AM
Mustang5L5's Avatar
I know we are nitpicking here. But isn't the exact definition of a true coil over a " coil spring over strut" configuration? With a seperate strut and spring setup, even if adjustable, the coil spring is not "over" the strut.
Not that it matters and we are getting away from the OP's question.
Old May 17, 2009 | 01:18 PM
ea_rsx's Avatar
Here is a link that explains everything.
http://www.splparts.com/main4/parts/...oiloverFAQ.htm
thanks
ea_rsx
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
