Noise after GF210 install
Old May 16, 2009 | 12:56 AM
skahide's Avatar
I have a 04 coupe. Yesterday i installed a set of Tanabe GF210's for the 350z. Just the springs. Ride is rougher (no biggie) BUT the front passenger side ONLY is making a loose, rattle sounds, when i hit bumps. I have double checked everything, nuts, bolts, spring sitting correctly. Car drives fine, just the noise, ANY IDEAS???
Old May 17, 2009 | 10:41 PM
skahide's Avatar
Thanks for the help, it is fixed
Old May 19, 2009 | 04:27 PM
h0tsauce's Avatar
any pictures of the car after the drop?
did you install a camber kit?
Old May 19, 2009 | 04:28 PM
johannaccord1's Avatar
What was it?
Old May 19, 2009 | 10:34 PM
skahide's Avatar
No kit installed. After they settle a little i'll check them out, but they look great as of now. I'll try and take pics tomorrow. It is a HUGE drop on 17's, BUT I LOVE IT.
Originally Posted by johannaccord1
What was it?
Wasnt aware that i could tighten the shock nut that holds the spring on even more once the car was completely back on the ground. Fixed it perfectly.
Old May 19, 2009 | 11:25 PM
w0lv3121n3's Avatar
did u get an alignment after the install?
if no, does it drive fine?
Old May 19, 2009 | 11:41 PM
skahide's Avatar
No alignment yet. Been driving for almost a week, no prob. everything i read agrees that there shouldn't be an issue with driving, just might mess with tire wear if you go to long without alignment.
Old May 21, 2009 | 03:58 PM
skahide's Avatar
Well I took the HUGE challenge of putting 350z Tanabe GF210's on my G35 Coupe. WAS NOT FUN, but I got it done and LOVE IT. The springs have been on for almost a week, and already give it a nice drop, but should settle a little more. I can do a springmount mod to lower the back another 1/2 inch, to even it out. I have nothing done to the car but the springs and the rims. The rims are ol' skool JDM 17's. Got a good deal on them with good tires on them. They have been painted a couple times (to see what I like) and still don't know how I want to powdercoat them. Hope to get some 25mm spacers all around to make them more flush. The car hasnt been washed in a week and the center caps aren't even on car. Took pics to show drop.
Old May 21, 2009 | 04:09 PM
skahide's Avatar
Here is the before.
Old May 23, 2009 | 11:15 PM
skahide's Avatar
noone
Old May 24, 2009 | 08:25 PM
HXS's Avatar
HXS
wow, i just installed my GF-210s too and my rears aren't that high.
btw, what was the noise you're talking about?
Old May 24, 2009 | 10:30 PM
skahide's Avatar
What rims do you have? Mine are only 17's. Any pics?
Old May 24, 2009 | 10:52 PM
HXS's Avatar
HXS
i'm on 20's.
Old May 24, 2009 | 11:04 PM
skahide's Avatar
20's would make a huge difference on the gap. did you do springmount mod?
Old May 24, 2009 | 11:18 PM
HXS's Avatar
HXS
no i didn't.
did you make sure your rears are seated right?
