neg camber
Old May 28, 2009 | 10:34 AM
eurodre's Avatar
Originally Posted by Vrod-Mike
My car was aligned and the only thing not within spec is the front camber.
that's interesting because im at -1.6 in the front and I haven't noticed anything wrong
Old May 28, 2009 | 10:36 AM
06g35meister's Avatar
i run -2 all around, but im more of a handling guy
i adjust to -0.75 in teh rear for track days.
Old May 28, 2009 | 11:42 AM
vash_g35's Avatar
i have F 2.5, and R 3.25
Old May 28, 2009 | 12:28 PM
gzywzy1k's Avatar
is that a pos or neg camber?
Old May 28, 2009 | 12:29 PM
MikeGrote's Avatar
wow, notice any bad tire wear?
im in spec all around except for my front left tire.
Old May 28, 2009 | 12:32 PM
RADIOGUY21's Avatar
negative camber is better than positive for handling but not too much. Incorrect toe adjustments will eat tires quicker than camber. Im maxxed out at -1.3 in the front with Z springs and havent noticed any abnormal wear in the past 2K miles. I will be rotating every oil change just to be safe though.
Old May 28, 2009 | 12:37 PM
Klubbheads's Avatar
i got 15k-20k consistent miles from my tires with hard driving and -1.5-2.2 front and rear camber. I did switch the tires from one side to the other and got the most perfect wear on the tires with that much camber.
Old May 28, 2009 | 01:09 PM
MikeGrote's Avatar
maybe thats what ill do, just swap the tires to the other side if i see some wear on the inside of the tread
Old May 28, 2009 | 03:51 PM
vash_g35's Avatar
those are negative. Positive camber will look weird. If your looking from behind the car positive will look like this \ /. Negative looks like this / \.
I have uneven tire wear from the inside because mine is way out of spec. But like everyone mentioned already, out of spec toe is the most notorious on tire wear.
I had to set mine like that because of my drop height and wheel offsets... or else it will rub like hell. LOL
Here's my rear
Old May 28, 2009 | 08:56 PM
HipHopPro's Avatar
This is what two years with out a camber kit look's like (I have them now F & R)
pic taking with blackberry storm (wack) ;O(
Old May 28, 2009 | 09:00 PM
MikeGrote's Avatar
coulda told you that was going to happen without the kits. what were your camber specs for the front and rear?
Old May 28, 2009 | 09:07 PM
HipHopPro's Avatar
Front L 2.5 Front R 2.7 / Rear L 2.3 R 2.5 somewhere around that.
b/w can I still use the fronts?
Old May 28, 2009 | 11:40 PM
MikeGrote's Avatar
do not use any tire with cords showing through
Old May 29, 2009 | 10:19 AM
Q45tech's Avatar
Important to understand that oem spec are the amount of misalignment [sitting still] FOUND NECESSARY [by engineers during rolling testing at 55 mph] to correct to achieve best MPG.
Unfortubately very difficult for owners modifiers to secure rolling alignment data recorders to RECALCULATE the best STATIC ALIGNMENT NUMBERS.
Just because something is at the ragged edge of inspec doesn't mean it is correct the NOMINAL [midpoint] is the CORRECT NUMBER!
(-1.9 to -0.9) nominal [ideal] is - 1.4 rear +- 0.1 degrees.
The oem numbers assume BRAND NEW BUSHING with a specific amount of preprogrammed flex and compression [not cracked worn aged bushings].
Old May 29, 2009 | 10:26 AM
  #30
gzywzy1k's Avatar
i put new wheels and tires on my car with 275 tires in the rear. does that have any effect on tire wear and camber? im still trying to solve the tire wear problem. i had to replace my rear tires once already, got about 9,000 miles out of em. that is unacceptable. and no i wasnt driving like an a$$hole. when i had the new tires put on i had them chack the allignment and camber and they said they were within spcs. should i increase the camber from neg 1.4 or whatever to like 0? or like -.4?
