Camber/ Dealership Help
Old Jun 3, 2009 | 05:12 PM
  #31
cremaster's Avatar
of course the dealer will tell you you're 'way off.' that's their job. if you take it to a performance shop they may tell you a -2 is still ok but that your tires will get eaten up more quickly.
i'm running over -2 in front and back; like the way it handles and will deal w/ the tire wear when it happens. if you want to be back in specs, get the camber kit.
also, yes, the front you cannot adjust the camber; if you want to "even out" the camber on each side, a good shop can perform a 'cradle shift' to even it out. should only cost about $40.
Old Jun 3, 2009 | 06:28 PM
  #32
redlude97's Avatar
A good alignment shop does the adjustments with the car ballasted to account for your weight in the driver seat. If this wasn't done, then getting both sides even is kind of pointless since it will change anyways once you get in and load up the left sid of the car.
Old Jun 3, 2009 | 10:08 PM
  #33
toymachine2009's Avatar
Ok im a little confused on this post. You say my camber is not that bad. and what do you mean a shop can "cradle shift" to even out my front. What will evening my front camber do?
Old Jun 4, 2009 | 12:28 AM
  #34
cremaster's Avatar
if one side has got say, -1.5 while the other has got -0.9, since our cars can't adjust the front camber, they can do a "cradle" or "subframe" shift to try and even the negative camber for both sides. i had this problem. the toe would be spot on but one side had more neg camber so it was causing my ride to pull to the left. hope that is more clear.
Old Jun 4, 2009 | 01:18 AM
  #35
thanks man
Marlin84
Apr 1, 2020 12:52 PM
ChrisAult2004
Sep 11, 2015 10:33 PM
Dmill86
Sep 6, 2015 08:14 PM
UT G35
Sep 3, 2015 03:58 PM
nightowl.czc
SouthEast
Aug 28, 2015 08:36 PM
