fix front camber without kit
Old Jun 8, 2009 | 01:21 AM
g35maraj's Avatar
is there any way to fix my front tire from uneven wear? without a camber kit?
i once had a 96 maxima and took it to miami auto chasis, and they corrected my front tire wear, on the maxima i had eibachs with 1coil cutt off, on the g35 i have sportlines??? any help guys??
Old Jun 8, 2009 | 01:44 AM
Skaterbasist's Avatar
Retired SuperMod
If I recall, the stock camber settings for the front cannot be adjusted without a kit. Toe can be adjusted to a certain degree without a kit.
Old Jun 8, 2009 | 07:48 AM
EL-EE-ES's Avatar
+1 there is no camber adjustment on the front. there is a shop in my area that says they can heat and bend arms to get them back into specs, of course the g drivers in the area stay far away them
Old Jun 8, 2009 | 08:51 AM
JC-RH's Avatar
I've had another car done without a kit at Miami chassis. I was thinking obout taking the G soon for the front also. I'm sure they can do it. Let's get a group buy going.
Old Jun 9, 2009 | 04:53 PM
prj3ctm4yh3m's Avatar
are you serious? is this a serious posT?
Old Jun 9, 2009 | 07:23 PM
JC-RH's Avatar
Yes, everything was serious except the part about the group buy. But even that's not far-fetched. Why, is there a problem?
Old Jun 9, 2009 | 07:34 PM
redlude97's Avatar
post your pre/post alignment numbers then. How did they go about adjust camber in the front?
Old Jun 9, 2009 | 07:43 PM
JC-RH's Avatar
It was for a 2003 civic. I've only done the rear on the G. So far so good. I don't have any #s to post.
Old Jun 10, 2009 | 02:09 PM
redlude97's Avatar
So then how are you so sure they are going to be able to adjust something that has no adjustment? Magic?
Old Jun 10, 2009 | 02:16 PM
KSWAY's Avatar
You know how the magician makes forks bend by just staring at it?
I think it's kinda like that..
Old Jun 10, 2009 | 10:45 PM
g35maraj's Avatar
kao do u think they bend the a-arms? would this be safe?
Old Jun 11, 2009 | 04:54 PM
heyitzalex's Avatar
I could've sworn it was the fronts that have some adjustability, and the rears that have none, hence everyone tends to get camber links in the rears.
I was going to ask this question as well, but I was wondering if anybody new how much adjustability there was?
Old Jun 11, 2009 | 05:20 PM
redlude97's Avatar
fronts only have toe adjustment, no camber at all. Rears have a small amount of camber and toe adjustment. The reason people usually buy the rears is because the fronts are significantly more expensive, and the rear tires wear down faster than the fronts anyways, so if the front wear down prematurely due to camber/toe, then you just replace all 4 tires at once.
Old Jun 12, 2009 | 06:46 PM
JC-RH's Avatar
I called Miami Chassis earlier today and they quoted me $200 for front camber correction and alignment. No kit required. They do good work there. Don't ask me how they do it, just call them yourself. They're located in Miami, FL.
Old Jun 12, 2009 | 07:01 PM
redlude97's Avatar
they are full of sh*t. Get a before and after printout, see if it changed.
