Bleeding Brakes?
Old Jul 14, 2009 | 08:41 PM
Anthens_G's Avatar
Bleeding Brakes?
I just wanted to know is bleeding the brakes always part of the process when changing rotors and pads? Also, is $160 a fair labor price to change front rotors, rear rotors and pads?
Old Jul 14, 2009 | 09:05 PM
EL-EE-ES's Avatar
You don't need to bleed them. Is 160 with pads and rotors or labor only?
Old Jul 14, 2009 | 09:10 PM
Anthens_G's Avatar
The $160 is for labor only, I have my parts already.
Old Jul 15, 2009 | 01:54 AM
vq35dedriver's Avatar
do it yourself real easy, save $160
there is a DIY on this forum
Old Jul 15, 2009 | 07:26 PM
reconJDM's Avatar
Since you live in NYC, do you drive your G all season? I would say soak the bolts with PB Blaster and let it sit for a bit before you go wrenching away.
Make sure to torque the bolts back to spec to be on the safe side.
If you are handy then do it yourself, $160 is decent.
Old Jul 15, 2009 | 07:28 PM
Jeff92se's Avatar
Red Card Crew
Required? no. If you haven't flushed your brake fluid in 3 years+ it would be a good idea.
BradMD_96
Oct 6, 2015 09:31 AM
Gabe83714
Oct 6, 2015 06:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
