BRAKE and SLIP light on WHY? (not VDC)
Old Aug 2, 2009 | 08:16 PM
sweettalker's Avatar
Brake pedal fell to the floor!
My car was looking brake pressure and the brake pedal was soft so I drove around for awhile because it didn't get any worse. Last night, the pedal fell to the floor and it lost all pressure. Now i have to pretty much brake to the floorboard to stop the car. I can't even hard brake. ALSO, when i brake (to the floor), the steering wheel sways to the right. Almost feels like my driverside brakes are working harder than the passenger. Then today, my SLIP and BRAKE and VDC light came on. What could this be? today is sunday so I can't do anything, I will probably go bleed brakes tomorrow. Is my fluid low? I have yet to check because it's so hot outside maybe I will check later tonight. Anyone else have this issues? BTW, I have 4pot wilwood bbk front and oem brembos in the rear. My car did not come with it, so maybe it's stressing the whole system perhaps master cylinder? But mine is an 05 with 2piston brake stock so i don't think that should matter.
Old Aug 3, 2009 | 10:14 AM
obender66's Avatar
check fluid level and do visual inspection for leaks. Do not drive the car.
Mry
Mar 3, 2023 01:03 AM
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
newg37
Jul 26, 2015 09:32 AM
