Camber Kit Question?
Old Aug 6, 2009 | 03:13 PM
Bo bo the clown's Avatar
I recently installed and SPC camber kit for Front/Rear.
I took the car to get align, now the problem is whenever I'm in a stand still and move the steering wheel either to the right or left the front of the car move's as well to the direction I'm moving the steering wheel to. Has anyone experience this?
Old Aug 6, 2009 | 07:04 PM
Xet's Avatar
Xet
wait so you turn your wheel when you arent moving and the tires move to the correct direction, like as if you were driving??? if so that always happens but you shouldnt do it
Old Aug 7, 2009 | 09:21 AM
I'm confused by your answer. But let me explain it better because I sucked at explaining it last time.
If I turn wheel either direction, the front of the car shift the direction the steering wheel is moving as if someone is picking it up from the front and moving it, that's the best description I can give, it's weird but just wanted to know if it's normal?
Old Aug 7, 2009 | 10:25 PM
FenixL1P's Avatar
i don't think that is normal, but that is me... your car should be stationary and not move at all when steering your car or any car at a standstill.. may need realignment...
Old Aug 17, 2009 | 06:59 PM
mitsuman's Avatar
this is normal.
think about it, when you turn right, you are riding mostly the outside of your right tire and the inside of your left tire.
When you turn left, your riding mostly on the outside of the left tire and the inside of the right tire. that shift in weight will make your car move slightly.
now not sure how bad it is, but i believe what you explained is normal.
jsimonk
Dec 22, 2023 03:49 PM
paolojericho11
Sep 11, 2015 07:08 AM
socalg35x
Aug 7, 2015 09:36 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
nascarbuff17
Jul 16, 2015 10:23 AM
