BBK: Best bang for your buck!
Old Aug 23, 2009 | 12:37 AM
CDN_G35's Avatar
So, I'm looking into re-doing my brakes and wanted to know what the best setup I could get for my money was. I'm not on a huge budget so I would need something affordable and I only want something that stops a bit better than stock. Does anyone have any suggestions. Keep in mind, it must clear my 20" MRR GT1's.
Old Aug 23, 2009 | 12:47 AM
Xet's Avatar
Xet
search akebono
Old Aug 23, 2009 | 01:55 AM
Derek173's Avatar
Yea the stock G37 Akebono would be good or some used brembos from 03-04 G35/350z.
Old Aug 23, 2009 | 10:19 AM
NNOCENT's Avatar
ditto.
03/04 Brembo's for ~$1200
09 Akebono's for ~$1850
Old Aug 24, 2009 | 12:31 PM
G35fromPA's Avatar
Define "stops better than stock".
Old Aug 24, 2009 | 01:25 PM
twin001's Avatar
upgraded pads will help you stop quicker. BBK's help disipate heat better and reduce brake fade over repetitive stops.
Old Aug 24, 2009 | 01:38 PM
Jeff92se's Avatar
Red Card Crew
BBK clearance of your wheels will probably be the biggest influence. If you DON'T have clearance, then something like Racing Brake's oem bbk upgrade might be for you. Upgrade to their 2pc rotors and you'll have a nice setup. Won't have the caliper bling though. But you can upgrade to those later
Old Aug 24, 2009 | 03:34 PM
G35fromPA's Avatar
Highly debatable. Depends on the pad, conditions, etc. Unlikely that you'll find any aftermarket pad that stops the car in a shorter distance than OEM on the first couple of stops, or at least appreciably so.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
Gabe83714
Oct 6, 2015 06:40 AM
5150DS
Sep 26, 2015 07:47 PM
