Help.... Spacers
Old 08-28-2009 | 09:57 AM
Pepper's Avatar
Help.... Spacers
I am waiting for my Tein Flex's to come in... I have Volk GT-S and all 4 corners of the car are rolled. I want the wheels to be more flush. 255/275 are the current tire sizes. I dont want to go overboard but a little more flush never hurt anyone What size spacers would be best? I do plan on have a camber kit on the rear btw...
Old 08-28-2009 | 10:45 AM
Deezflip's Avatar
I would wait til you get the camber and the camber alignment, then you'll see how much room you have to work with. If I'm correct, the camber alignment will bring the top of the tire outwards.
You might also want to post some offsets
Old 08-28-2009 | 08:07 PM
EL-EE-ES's Avatar
+1 we need to know your offsets
Old 08-28-2009 | 08:09 PM
gtrefever's Avatar
yes offsets shoulda been the main thing you posted.
Old 09-01-2009 | 09:45 AM
Pepper's Avatar
the standard GT-S offsets... +17 F +18 R
Old 09-01-2009 | 12:16 PM
eurodre's Avatar
well its hard to tell you what size because we don't know how low your car is
best thing to do is measure from the wheel out to the fender and use that as a general estimate
Old 09-01-2009 | 01:13 PM
Pepper's Avatar
i want to dump the car to the most reasonable height because its not a daily driver....
Old 09-01-2009 | 01:16 PM
Pepper's Avatar
I was looking for an overall drop from current height to 1-2" lower...
Old 09-01-2009 | 01:37 PM
GreenGoblin's Avatar
The goblin resurrection
I would say 10mm around then you do not have to worry about running to much camber.
Old 09-01-2009 | 03:42 PM
Pepper's Avatar
Theres no real way to run 0 camber without stretching the tires right?
Old 09-02-2009 | 02:19 PM
Johnnyone's Avatar
Will he need the extended studs for 10mm?
Old 09-02-2009 | 03:12 PM
jayk's Avatar
Id have to say from the height you mentioned (1-2" more than your picture) 10mm all around would probably be good. you will have a lot of NEG camber though. im thinking in like the 3 range.
Old 09-02-2009 | 03:15 PM
Calvin's Avatar
Overglorified Altima
Why would you ever run 0 camber?
Old 09-02-2009 | 03:27 PM
eurodre's Avatar
just get camber kits and you can adjust the camber
but due to the bigger tires you might need to run more camber, sorry gotta pay to play
but dont run 0 camber.. instead run 0 toe
Old 09-02-2009 | 03:31 PM
jayk's Avatar
i like this post because its just soo contradicting. lol.
Quick Reply: Help.... Spacers
