OEM Brembo Swap Snag
Old Sep 4, 2009 | 08:40 PM
XDR-V35's Avatar
Started the install tonight and got the driver front installed with z1s performance package, went to install the wheel and it does not clear the wheel due to backspacing. Picking up 5/16 wheel spacers tomorrow to hopefully clear the callipers. Will post pics when finished tomorrow.
Old Sep 4, 2009 | 08:41 PM
G SEDAN's Avatar
make sure to get extended studs with that!
Old Sep 4, 2009 | 08:54 PM
nghiars's Avatar
or look for some wheels that will clear the brakes. 7 spoke oem coupe 18"s, 350z oem 18 touring wheels, oem rays 19"s
Old Sep 4, 2009 | 09:08 PM
XDR-V35's Avatar
I have 19" ADRs right now, eventually will probally go with staggered 18s
Old Sep 7, 2009 | 11:01 AM
XDR-V35's Avatar
got everything on, couldnt find extended wheel studs locally so found some nuts that temporarly installed the wheels, ordered nismo 60mm studs, here are pics of them installed.
Old Sep 8, 2009 | 08:13 PM
Bestswat's Avatar
So let me get this straight to do the brembo swap to a non-brembo car you will need the brembo brake lines,brembo rotors,brembo calipers, and brake pads(brembo)?
Then afterwards get some spacers or get some wheels with extended studs that will fit the calipers?
Old Sep 8, 2009 | 08:21 PM
XDR-V35's Avatar
part one of your question is correct.
part two depends on your wheels, I think all stock wheels will clear the calipers with out spacers or the extended wheel studs. my wheels did not clear the front calipers so i needed 5/16 wheel spacers and to use those i needed the extended wheel studs.
hope that cleared it up for you
Old Sep 8, 2009 | 10:19 PM
Bestswat's Avatar
Ohh ok, yea that cleared it up for me thanks.
How big of a difference was the swap? Is it worth it in your opinion?
Old Sep 9, 2009 | 08:03 AM
XDR-V35's Avatar
well right now im on hold for my extended wheel studs, but for appearance they are 100 times better. my rotors were giving me feedback on the stock setup so i decided to do this to permanently solve the problem
Old Sep 15, 2009 | 09:13 AM
XDR-V35's Avatar
yet another issue.. brakes and everything work perfect. now i have tire rub issues on the rear, every little bump pushes the side wall into the lip and cuts the tire.. time to get the fenders rolled. it sucks only having less than 2 fingers space between tire and fender......
Frankieg35
Mar 20, 2016 09:42 PM
Frostbite91
Aug 12, 2015 05:16 PM
mcneil_g35
Lighting
Aug 5, 2015 01:09 PM
mushu
Jul 15, 2015 03:55 PM
