Total noob here, got some suspension questions
OK, So I ordered a set of the g35 tein s techs ( I Know I should gotten the 350z stechs) and I also ordered a kinetix camber kit.....now my question is this, will that be all I need to ensure that I dont get any uneven tire wear? Or will I need more....also, how do I adjust the camber? When I get it aligned will they know what to do and do it for me? Any help would be greatly appreciated....
^ if you get the alignment with the camber kit they'll adjust the camber
don't forget toe causes tire wear as well.
do you have a coupe or sedan?
if you have a sedan and bought coupe s techs, then you might run into problems with the rear having more toe. but if it's a coupe you shouldn't have to worry.
i have a coupe and i'm running eibach prokits without a camber kit. the camber's only about -1.5
FS[Texas]: KSport Air Suspension G35/350Z/M35
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
kinetek
Aug 3, 2015 04:25 PM
