Help: 1 month old brakes squealing!
Old Sep 15, 2009 | 09:54 PM
cpufreak3's Avatar
So I bought new ceramic brake pads and cross-drilled/slotted rotors last month and had them installed.
All was fine until last week when the brakes started squealing.
They only squeal when I apply light to medium pressure and am coming to a stop. At higher speeds or immediate braking, they don't squeal.
Any idea what the problem is and how to fix it? Thanks
Old Sep 15, 2009 | 10:23 PM
phunkenstein's Avatar
Company Pads // Company Rotors?
New Brake Lines?
Old Sep 15, 2009 | 10:33 PM
cpufreak3's Avatar
They were ordered from 88Rotors.
I believe they are made by them?
EDIT: So I called them, the pads are Verto ceramic pads, rotors are in-house (88Rotors).
I did the bedding process which stopped the noise, but it's back today (not as bad).
- Does bedding really help with squealing, or am I masking the real problem?
Old Sep 17, 2009 | 05:16 PM
cpufreak3's Avatar
Bump added more info ^
Also, would drilled/slotted have any affect on the squealing (as in cause it).
Old Sep 17, 2009 | 10:18 PM
G35fromPA's Avatar
Did the shop reinstall the factory brake shims or use enough brake lube?
Old Sep 17, 2009 | 10:27 PM
cpufreak3's Avatar
1. I don't think he used the factory brake shim
2. I saw him apply some brake lube, but I have no idea if this stuff wears out or if it wasn't enough
The thing I wanna know, is it more likely an install problem or a parts problem? Because each party is blaming the other...
Old Sep 18, 2009 | 12:13 PM
G35fromPA's Avatar
Likely it's the shims:
http://auto.howstuffworks.com/auto-p...rake-shims.htm
chinee
Jun 10, 2024 07:48 PM
11bEMT
May 27, 2022 03:13 PM
G35CO
Aug 25, 2015 02:00 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
Lsantana757
Jul 20, 2015 09:08 AM
