Rear camber install. Toe bolt?
Old Sep 23, 2009 | 11:23 PM
DanielsG's Avatar
Hey guys sorry if this has been discussed before but i need a fast answer and couldn't find it searching. I just installed my rear camber kit that included the TOE bolts. I know that in order to realign to factory spec i need to cut the holes of the toe bolt towards the inside of the car. -> <- like that. But i have a few questions.
1. How does that allow for more adjustability??
2. Will simply using the Toe bolt help align it better that using the stock one?
3. How far do i need to dremel 1/2'' 1/4''?
4. What is the best dremel bit to use?
BTW: Im dropped on sportlines.
Thanks!!
5. so i dont have to start another thread-
I just bought some GFG laguna's and need tires. The tires on them now are
245/35/20 front 275/30/20 rear Should i buy the same sizes? or should i
do 30 in both front and back or 35 in both front and back???
Old Sep 24, 2009 | 01:28 PM
redlude97's Avatar
This has all the information you need
http://my350z.com/forum/brakes-and-s...-protocav.html
Make sure you dremel and install the toe bolt on the end of the spring bucket, not the camber arm. A lot of people make that mistake. For the tires you should go with either 245/30/20 or 255/30/20 for the front and 275/30/20 or 285/30/20 for the rear
Old Sep 24, 2009 | 01:49 PM
DanielsG's Avatar
thanks redlude
Old Sep 24, 2009 | 01:52 PM
DanielsG's Avatar
BTW. what is the end of the spring bucket? is that on the side of the camber arm closest to the center of the car. or are you saying it does not even go on the camber arm at ALL.
Old Sep 24, 2009 | 01:56 PM
DanielsG's Avatar
The link doesnt work. it brings me to the turbonetics forum but no PDF.
Old Sep 24, 2009 | 02:24 PM
Drewer's Avatar
Re upped here:
http://www.batit.com/forumpics/spctoeboltinstall.pdf
Dremel carbide bit #9933
Old Sep 24, 2009 | 06:15 PM
DanielsG's Avatar
Originally Posted by Drewer
Re upped here:
Thanks buddy.
Old Sep 24, 2009 | 07:02 PM
redlude97's Avatar
It doesn't go on the camber arm AT ALL. It goes on the spring bucket, the arm that holds the rear spring in place.
Old Sep 25, 2009 | 02:03 PM
DanielsG's Avatar
i understand now. the photo helped. Thanks a lot guys for making it clear.
EPG35
Aug 16, 2015 04:52 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
beevanhuynh
Jul 23, 2015 01:37 AM
