Suspension Question
Old Sep 25, 2009 | 03:05 AM
only1waqas's Avatar
Suspension Question
Currently i have Tein S Tech for G35 Coupe....
Suspension does not have a camber kit...
I just replaced my 20's with OEM 19's. The tires have lots of tread and the car is drifting to the right.
I was thinking about getting alignment for right now before i save up and get camber kit....
My question is since i dont have camber kit will the alignment help from making my car drift to the right?
Should i get alignment? My car is drifting a little to the right when i let go of my steering column....
Thanks for your input
Old Sep 25, 2009 | 03:50 AM
dofu's Avatar
20 Year Member
Get an alignment. Remember that toe is more important than camber. Get, at the least, a camber and toe kit for the rear too , ASAP because you'll have lots of toe on the rear wheels, losing stability at speed. You won't be able to fix the front camber right now, but at least the front toe is already adjustable from the factory.
Old Sep 25, 2009 | 01:24 PM
only1waqas's Avatar
Thanks will get an alignment, do i need to tell them anything special?
Old Sep 25, 2009 | 01:28 PM
dofu's Avatar
20 Year Member
If they need you to tell them anything besides "My car is lowered with a rear toe bolt and rear camber kit etc...", then you should just take your car somewhere else instead.
Old Sep 25, 2009 | 01:50 PM
only1waqas's Avatar
I dont have a rear camber kit or toe bolt...
Old Sep 25, 2009 | 02:32 PM
only1waqas's Avatar
Ok to clarify I DONT have rear camber kit or toe bolt.....
Old Sep 26, 2009 | 12:24 AM
Joe_Camel's Avatar
You seem easily confused, so I'm gonna say no, you don't need an alignment.
You should get an alignment.
Good luck.
jsimonk
Dec 22, 2023 03:49 PM
rezendvous420
May 31, 2020 01:26 PM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
