Picture request : g35 coupe on eibach prokit/tein stech/tanabe nf210
Old May 3, 2010 | 01:17 PM
  #31
BLACK-G35TT's Avatar
G35 Tein Stech
Picture request : g35 coupe on eibach prokit/tein stech/tanabe nf210-100_1160.jpg
Picture request : g35 coupe on eibach prokit/tein stech/tanabe nf210-100_1333.jpg
Old May 3, 2010 | 03:14 PM
  #32
L23Tan's Avatar
Originally Posted by A.Chambers
I still have them on the car. They are good springs, and have a comfortable ride. The thing I dont like about them is that initial spring rate being lower than the stock spring rate. I added swaybars and that helped a lot as far as handling goes, but will probably replace the Eibachs.
Stock springs on my car (04 g35 6mt) is 314f/342r
Initial rate on the Eibach is 296f/316r final rate is 337f/421r
The springs I am most likely going to try next are the RSR for the 350. They would drop the car approximately 1.2" with a linear rate of 345f/417r
The revised 350z spring actually has a higher rear spring rate than any of these (427) so I am still going to use the stock shocks. They have been working well so far with the Eibachs.
Thanks for the reply.
Right now, I've been researching all the spring options, spring rates and all that and I think I've given up on trying to match my oem sport tuned suspension rates of 314f/427r. I'm just going to pick a spring and be done with it.
Since you bought the 350Z Pro Kits, which are rated at a -1.0" drop all around, would you agree that all 350z springs, if installed on a G35 Coupe adds an extra -0.5" drop to the advertised 350z drop? So, you're dropped a total of -1.5" all around. I look how this looks!!!
I'm asking because I'm really leaning towards purchasing SWIFT Sport Springs (Linear). The SWIFT G35 advertised drop is -1.0"f/-0.6"r with spring rates of 280f/314r. The SWIFT 350z advertised drop is -0.8"f/-0.6"r with spring rates of 336f/364r, should actually be -1.3"f/-1.1"r when installed on the G35 Coupe. (this drop should be very close to the 350z Pro Kit drop) I'm leaning to wards the SWIFT 350z Sport Springs. No one else seems to have this set up, so I might just take the jump!
Old May 3, 2010 | 03:21 PM
  #33
A.Chambers's Avatar
I would say no one has them because they are a softer spring. You will increase body roll and it would have a negative effect on the handling of the car IMO.
I would say the 350 pro kit dropped me about 1.5 inches. Here are some more recent pictures... These are with 25mm spacers front and rear.
Old May 3, 2010 | 03:45 PM
  #34
L23Tan's Avatar
Requesting better pics with the entire car in the sun!!!
Old May 3, 2010 | 03:47 PM
  #35
nyfelix87's Avatar
Eibach ProKit
Old May 3, 2010 | 11:44 PM
  #36
L23Tan's Avatar
Which Pro Kits are those? 350z or G35?
Are you on stock shocks?
DAMN! NICE WHEELS!!!
Are those 19's?
Tire size?
Old May 4, 2010 | 12:39 AM
  #37
is3turbo's Avatar
nice and clean guys
Old May 5, 2010 | 08:34 PM
  #38
iFRANChISe's Avatar
I forgot to come back and post in this thread. Here's mine with 350z eibach prokit.
Old May 5, 2010 | 08:52 PM
  #39
L23Tan's Avatar
awesome shots iFranchise!!!
beautiful car and nice stance too!
Old May 8, 2010 | 11:00 AM
  #40
nyfelix87's Avatar
Are those 19's?
Tire size?
G35 prokit
Stock shocks
THanks, they are 19's 255/40 front 275/35 rear
Old May 10, 2010 | 11:35 AM
  #41
A.Chambers's Avatar
More pictures.....
350z pro kit, 30mm rear spacer, 25mm front. (rears rolled)
Old May 13, 2010 | 03:12 AM
  #42
BokChoiBoi's Avatar
Hows your camber after getting the pro kit?
Im liking the drop from them but now im curious if ill need
front and rear camber kits or just rear?
Loving the cars guys maybe ill get to post my prokit drop on here if i get them
Old May 13, 2010 | 03:19 AM
  #43
Jairen's Avatar
I think you guys should also note if you did the spring mount mod in the rear or not.
Old May 14, 2010 | 07:22 PM
  #44
verilath's Avatar
G35 Tein S-Techs. Stock Shocks. No Springmount mod.
Old May 15, 2010 | 10:27 AM
  #45
A.Chambers's Avatar
I was able to get back in spec with just the rear camber arms. Did not need a front camber kit or the rear toe bolts. From what I have heard though it is different for different cars. I would suggest getting the springs, installing them, ride around for a week or 2 and let them settle. Go to Firestone, pay for a lifetime alignment, and see how close they can get it. From that point you can decide what you need to get everything back in spec. Purchase/install those items and them go back to Firestone for another alignment. Think I paid $120 for the lifetime alignment and have had it aligned 3 times already in the past 6 months. First time after springs settled, second time after I installed the camber arm, third time after it was icy here in NC and the roads were terrible, just to make sure it didnt knock anything out of spec.
