powerdcoated oem brembos..
Old Oct 6, 2009 | 12:52 AM
G35-31's Avatar
anyone know about how much to have my oem brembo calipers would cose to get powdercoated? rough est.
Old Oct 6, 2009 | 01:01 AM
O HELLA OEM's Avatar
no more then $500 i believe
Old Oct 6, 2009 | 02:24 AM
Tollboothwilley's Avatar
depends. I was told i could get them done for around $200 for a set of 4. But I heard that you have to rebuild the calipers because of how it works.
Old Oct 6, 2009 | 03:19 AM
4DGS's Avatar
Whoa $500? Even $200? ****.
My powdercoating guy does wheels for $200 plus sandblasting. All 4....
I would say less than $100 to $150, I don't know anything about the rebuild though.
Old Oct 29, 2009 | 02:12 PM
lightspeed1's Avatar
In New York, $300 all 4 four any color you want. you can mial them to Prodigy Coatings> tell Joe Pedro sent you.
Old Oct 29, 2009 | 02:15 PM
Dubi2087's Avatar
It shouldn't be too much, maybe around 100-150, but you WILL have to rebuild them so it will still be more than 150.
Old Nov 1, 2009 | 01:49 AM
mdeezy's Avatar
the oven the put the calipers in the complete the powder coating process is too much heat for the piston boot and certain parts in the caliper... its best to remove all components from the caliper then have them powder coated then rebuild the caliper...
Old Nov 3, 2009 | 09:05 AM
GreenGoblin's Avatar
The goblin resurrection
Cost me $400 including rebuild.
Old Nov 3, 2009 | 10:31 AM
roshique's Avatar
I own a powder coating business www.rkpowdercoating.com based on what part of the country you are in the prices of powder coating will vary. Prices will also vary depending on the size of the shop you have our work done at. Since I powder coat on the side out of my garage and I have less overhead than a larger shop would, the prices that I charge are generally lower.
Just to give you a rough estimate, not to solicit your business, I could do all four calipers for $175.
Because most powders cure at 400 - 450 degrees, you will need to rebuild your calipers after they are coated.
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
johnadlertech
Lights
Sep 4, 2015 12:35 PM
johnadlertech
Interior
Sep 4, 2015 12:26 PM
erich2780
Sep 3, 2015 03:23 PM
