6 piston vs 4 piston
Old Oct 9, 2009 | 08:35 PM
highoutput's Avatar
this has probably been debated before, but i cannot find a true answer. is there much difference between a 6 piston caliper vs a 4 piston caliper? other than size of course and number of pistons making evenly pad/rotor wear, but as performance and reliability, does it really matter whether you go with 4 or 6?
Old Oct 9, 2009 | 11:34 PM
Q45tech's Avatar
BMW uses a single piston system on some vehicles.
Every thing depends on the TOTAL Area of all the pistons combined.
2 floating piston calipers act like 4 piston fixed calipers 95% of the time.
As to street or mild racing the number of pistins is inconsequential as to stopping distance.
Old Oct 9, 2009 | 11:49 PM
ttrank's Avatar
Grocery getter
Read up on Stoptech or any of the other good racing brake sites.
That is what I did.
Depends on your driving style and where you drive.
Old Oct 10, 2009 | 08:52 AM
highoutput's Avatar
i guess what i really want to know is that "if you go with 6 or 4, is there one that is better as far as reliability? with 6 wouldnt that mean you have more chances of breaking? dont know just wondering?
Old Oct 11, 2009 | 04:04 AM
k67p67's Avatar
If that were true, then Tim you've got A LOT "more chances of breaking".
Old Oct 11, 2009 | 08:59 AM
Q45tech's Avatar
The more pistons you have the more bores and seals you have to replace and clean.
Old Oct 12, 2009 | 12:11 AM
highoutput's Avatar
would a 4 piston front with a 13" rotor matched with a 13.8" rotor 2 piston rear cause alot of bias transfer on the G?
Old Oct 12, 2009 | 12:26 AM
pfarmer's Avatar
I would think that the greater the surface area the greater braking force potentially applied and the more control possible due to a shorter throw with the same amount of pedal movement.
Old Oct 12, 2009 | 02:40 PM
G35fromPA's Avatar
You can use this: http://www.tceperformanceproducts.co...alculator.html
to figure it out. You'll need the piston diameters plus pad radial height and friction coefficients.
My 2004 w/Brembos (using OEM pads) has ~67%/33% F/R brake bias just by using the dimensions described in the FSM.
Old Oct 12, 2009 | 08:30 PM
highoutput's Avatar
tha hell should i know all these figures. LOL thanks this works
Old Dec 23, 2009 | 10:07 PM
Todd TCE's Avatar
Assuming the total area of the caliper is near or the same then total clamping is also.
One single, a twin, four pots, six, eight or more doesn't matter. It's AREA.
Like saying you weight more standing on two feet rather than one.
seagrasser
May 3, 2022 09:43 AM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
dcsbh1
Oct 1, 2015 03:15 PM
Ashton35
Jul 17, 2015 10:11 AM
