Tein Flex Rear Damper how to?
Old Oct 11, 2009 | 05:03 AM
KJG35's Avatar
Hey i just got some Tein flex's installed on my 06 G. I was wondering if anybody could tell me how to reach the rear damper's to adjust the stiffness
Old Oct 26, 2009 | 06:32 PM
syshs's Avatar
^ you outta luck man. if you dont have EDFC, you gota take the strut out to adjust the stiffness on the rears. i know, sucks.
Old Oct 26, 2009 | 07:37 PM
caskyline's Avatar
Former Vendor
^ That is correct.
The area above the shock is a dead cavity, it is not accesible.
Old Nov 1, 2009 | 11:52 AM
sliderg35's Avatar
It's accessible from the inside of the car! Why would you guys say it's not?!?! Think about it; if you can put on EDFC from the inside of the car, why wouldn't you be able to adjust them from the inside? It's been a while since I looked at mine, but I put the EDFC on quite a few months after I had originally installed the dampers and I had to adjust them prior to that point as well.
Old Nov 1, 2009 | 10:13 PM
syshs's Avatar
^ Ya, if you have EDFC. Obviously the OP does not have EDFC.
Old Nov 3, 2009 | 09:03 AM
GreenGoblin's Avatar
The goblin resurrection
You need to pull the shock, end of story.
Old Nov 3, 2009 | 03:38 PM
CreativeDesignZ's Avatar
personally, i had the same issue with my greddy type S coil overs i cut small holes in the sheet metal in my trunk, now i can just barely fit a few fingers in there to turn the adjustment ****.
Old Nov 3, 2009 | 03:45 PM
Alan's Avatar
follow my guide: https://g35driver.com/forums/brakes-...uspension.html
Old Nov 3, 2009 | 04:35 PM
thats a great guide but when you go to the track and need to change dampening that still takes way too long. Get a dremel and cut a few holes then put some rubber stripping around the holes so u dont cut yourself. you can then change ur suspension setting in about 30 seconds
Old Nov 3, 2009 | 04:38 PM
syshs's Avatar
^ Thats a great idea. I think Im gona do that.
Old Nov 3, 2009 | 05:57 PM
yup u just need to make an initial "guide" hole so you can see how much metal to take off, you dont want to come too close to the bottom where the strut is bolted into the car.
Old Nov 4, 2009 | 12:06 AM
sliderg35's Avatar
Ahh... sorry, I have a sedan - adjustment is easy from inside the car. The OP has a coupe. I guess that's another plus for the sedan guys.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
redonblack35
Accessories
19
Feb 13, 2016 11:19 AM
reavensf
Sep 17, 2015 11:30 PM
TreeFiddy
Aug 10, 2015 06:50 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
