Tein S-Tech Lower Springs on 2006 G35 Sedan
Old Oct 26, 2009 | 03:23 PM
jimmykce1's Avatar
I am getting Tein s-Tech springs for my sedan. I already have SPL Front Adjustable A-arms and Stillen Rear Adjustable Camber Arms. Will I need to get adjustable toe arms with these springs?
The S-techs will drop the front 2" and the rear 1.2".
Old Oct 26, 2009 | 05:19 PM
4DGS's Avatar
You should be fine with what you have.
Old Oct 26, 2009 | 07:19 PM
NjMatteSedan's Avatar
did you order the coupe S techs or sedan S techs?
Old Oct 26, 2009 | 08:04 PM
jimmykce1's Avatar
Its for the sedan. I am buying it from a guy off the NGC club. He ordered the wrong version.
Old Oct 26, 2009 | 08:25 PM
brettb21686's Avatar
do the s-techs for sedan go that low? I thought it was like an inch or so....
Old Oct 26, 2009 | 08:34 PM
4DGS's Avatar
You're thinking of H-techs.
Those are the right specs for S-techs.
Old Oct 26, 2009 | 08:39 PM
these s-techs work on the G35X correct? Every site doesn't specify which I'm guessing means they fit....
also, what are you using for camber? trying to buy all this stuff! appreciate it
Old Oct 26, 2009 | 09:28 PM
jimmykce1's Avatar
I am running SPL for the front and stillen rear for the rears now. I have 350z front and coupe springs now.
I don't these springs are made for an AWD G.
Old Oct 26, 2009 | 11:17 PM
Tollboothwilley's Avatar
S-techs lower it more than H-techs
Sedan H-techs .2 F and .3 R
Sedan S-techs .6 F and .7 R
according to their site
for coupe you can add another .5" of drop to the sedan specs
for 350Z you can add another 1" of drop to the sedan specs
Old Oct 26, 2009 | 11:36 PM
4DGS's Avatar
*****, I was talking to brett who was unsure that S-techs could take the sedan that low.
Old Oct 27, 2009 | 12:23 AM
thanks! appreciate the info, anyone know if they are definitely compatible with the X/AWD?
Old Oct 27, 2009 | 12:39 AM
4DGS's Avatar
Yes they are 100% compatible, just add a .5" additional drop to what the tein website says.
Old Oct 27, 2009 | 12:50 AM
gotcha...good to hear
went to the marketplace for THMotorsports camber kits.....says for the s-techs fronts are advised and rears needed
think its worth gettin the fronts just the same? or is it just necessary for the rear
Old Oct 27, 2009 | 12:54 AM
4DGS's Avatar
A local friend of mine has run S-techs for 2 summers now on previously used wheels and tires with no camber kit and he is yet to replace those tires.
It's suggested but not mandatory. Maybe drop it see how it wears the tires you have now and then if they are feathering buy the kit.
Old Oct 27, 2009 | 01:55 AM
alright then, maybe ill go that route....
what kind of shocks/struts is everyone running
