Motordyne Adjustable Sway Bars for the 350Z and G35.
Old Nov 21, 2011 | 02:55 PM
  #181
Hydrazine's Avatar
Originally Posted by matdaddy
Just wondering if their was a update on squeaks.. Im leaning towarsd stillen but need some help making up my mind..
Also are these compatible with SPL end links and tie rods ?
Probably but I havn't tried that combination myself.
The bars will fit like stock though.
Old Nov 21, 2011 | 09:33 PM
  #182
brandon1978's Avatar
How bad is it? Theirs so many too choose from .. I was leaning torwards Stillen but then everyone is running Hotchiks
I like Motordyne because of the service Tony provides to the G community. The stiffer the bar, the more likely the end links will make noise. My car is also lowered an inch, so that combined with the Motordyne sways set to Med was too much for the stock end links. The SPL end links rattle, but it is only noticeable at low speeds, like in a parking lot. If I was doing it again, I'd try a different brand of adjustable end links.
You experience could be different, especially if you aren't lowered. I recommend getting the sway bars installed first, then see if the end links make noise.
Old Nov 23, 2011 | 08:22 AM
  #183
matdaddy's Avatar
Thanks for the tip. I already ordered SPL Pro Outer Tie Rod End and SPL PRO Rear Endlinks due to a recommendation from my shop... Rattle at low speeds .. Everyone is running Hotchick so I was just wondering if there was a reason
Old Dec 20, 2011 | 05:04 PM
  #184
jrockstarr's Avatar
how long do these take to install and is it a easy DIY? what would a shop charge?
Do i need to buy bushings to install these or will they bolt right up with out issues?
Old Dec 22, 2011 | 01:36 AM
  #185
Hydrazine's Avatar
Its an easy install. Shouldn't take more than an hour. The kit comes with everything you need for a complete installation.
Old Dec 8, 2012 | 05:55 PM
  #186
flyz's Avatar
Got my sway bars today. Just wondering is the front bar supposed to be thicker than the rear? In the product picture, it doesn't seem so.
Old Dec 8, 2012 | 06:15 PM
  #187
Shanes_G's Avatar
Why are the black ?
Old Dec 8, 2012 | 06:18 PM
  #188
flyz's Avatar
Originally Posted by Shane-O-Mac
Why are the black ?
Just the lighting, white balance is a bit off. Fixed the original pic with correct colors.
Old Dec 8, 2012 | 06:34 PM
  #189
MaDMaXX's Avatar
Yup, front bar is much thicker, all normal, that's the same as stock style, the front being thicker.
Enjoy, these are great bars
Old Dec 8, 2012 | 07:11 PM
  #190
Shanes_G's Avatar
Anyone have a set they wanna get rid of?
Old Feb 27, 2013 | 08:05 PM
  #191
.cakestar's Avatar
can anyone else confirm that the newest bars only have two holes on the front sway? is it just mine?
Old Feb 27, 2013 | 11:16 PM
  #192
Hydrazine's Avatar
Originally Posted by flyz
got my sway bars today. Just wondering is the front bar supposed to be thicker than the rear? In the product picture, it doesn't seem so.
yes.
Old Feb 27, 2013 | 11:18 PM
  #193
Hydrazine's Avatar
Correct. The 3rd hole was so close to stock it was redundant.
Old Feb 20, 2014 | 06:36 PM
  #194
MikeG3537's Avatar
Still available?
Old Feb 20, 2014 | 08:53 PM
  #195
MaDMaXX's Avatar
Should be, give 'em a call.
