Motordyne Adjustable Sway Bars for the 350Z and G35.
Old Feb 22, 2011 | 02:24 PM
  #166
jstudrawa's Avatar
Are these painted or powdercoated?
Sorry, didn't read every post.
Local powdercoater will do them black, but the price varies on whether he needs to sandblast the paint off or just cover the powdercoating.
Old Feb 22, 2011 | 07:08 PM
  #167
Hydrazine's Avatar
Definitely powdercoated. Its the only way to go for parts like this.
Old Mar 12, 2011 | 12:26 AM
  #168
lotteman's Avatar
I promised Tony I would tell him what I think of these so I'll probably write a review later this month. I've been playing around with as many of the possible settings between front and rear. Since gas prices have shot up this month its been hard to go out and test each and every setting. I know this much so far:
THEYRE GREAT AND WELL WORTH THE MONEY
Old Mar 12, 2011 | 01:06 AM
  #169
deuce3333's Avatar
Does anyone know what size urethane bushing I would need to go with the motordyne sways. When I order these sways I would also like to order some urethane bushing? Thanks
Old Mar 12, 2011 | 08:06 AM
  #170
lotteman's Avatar
For the rear, I know you can use the same size as stock but I'm not sure about the front since the Motordyne sway bar is much thinner than stock.
Old Mar 17, 2011 | 01:20 AM
  #171
B_Lam's Avatar
So.. where can i get a set of these sway bars?! I'm near LA area...
Old Mar 17, 2011 | 12:25 PM
  #172
lotteman's Avatar
You can save yourself the cost of shipping and pick these up direct from Tony(hydrazine) He's located in Santa clarita valley.
MotorDyne Engineering
26977 Whitehorse Place
Canyon Country, CA 91387
Sales (661) 298-7555
Tech (661) 993-5111
E-mail: info@motordyneengineering.com
I recommend calling him in advance to let him know you're coming.
Old Mar 17, 2011 | 01:10 PM
  #173
B_Lam's Avatar
Tech (661) 993-5111
Thanks man! I'll definitely hit him up soon.
Old Mar 17, 2011 | 01:24 PM
  #174
gbert15's Avatar
Hey im in la as well! Might think of picking these up too!
Old Mar 17, 2011 | 01:31 PM
  #175
juan350gt's Avatar
Wow these are next on my list. after the Motordyne 5/16 thermal spacer and the Mrev2 under plenum.. I will also like to conclude that picking them up is better and faster and cheaper for you since you don't pay the shipping and tony doesn't hastled to ship..
Old Mar 31, 2011 | 12:14 AM
  #176
EastBayG35's Avatar
How much shipped to 94565? Do these require the OEM endlinks to be upgraded?
Old Nov 20, 2011 | 12:10 AM
  #177
matdaddy's Avatar
Originally Posted by Hydrazine
No squeaking noises at all. None.
These use the greased rubber bushings. Not the hard plastic ones that squeak.
Just wondering if their was a update on squeaks.. Im leaning towarsd stillen but need some help making up my mind..
Also are these compatible with SPL end links and tie rods ?
Old Nov 20, 2011 | 10:21 AM
  #178
Texasscout's Avatar
Had my Hotchkis on for three years, they use the polyurethan bushings with synthetic grease. No noise at all.
Old Nov 20, 2011 | 04:09 PM
  #179
brandon1978's Avatar
Properly greased swaybars shouldn't squeak. A stiffer bar can put more load on the end links which may cause them to make noise.
Yes. I have SPL end links and the Motordyne swaybars. The stock end links made binding noises after installing the swaybars so I replaced them with SPL end links. The SPLs make a different noise. Can't win, but don't want to go back to stock either.
Old Nov 21, 2011 | 07:48 AM
  #180
matdaddy's Avatar
How bad is it? Theirs so many too choose from .. I was leaning torwards Stillen but then everyone is running Hotchiks .. Then i found these Motordyne and once again i find my self second guessing...
I just want a quite swaybar.. I dont track my car ...
