Better handling, where to start?
Old Nov 19, 2009 | 02:06 PM
CreativeDesignZ's Avatar
yea im going to be switching to medium/medium and see how that is, the car is on rails the way it is
Old Nov 19, 2009 | 02:07 PM
G35fromPA's Avatar
Originally Posted by 4DGS
1. Sways first for sure
2. Drop, but I wouldn't go with the D-specs. I have heard some terrible things. Plus if you're spending $750 on that just buy tein Basic coilovers, they can be had used for $500-$700, new less than $1000
Dofu is spot on though.
What terrible things have you heard about D-specs?
Old Nov 19, 2009 | 07:12 PM
Blue Dream's Avatar
I drove ttrank's car solo
Originally Posted by CreativeDesignZ
i did to the research and i was told after market endlinks were what i needed. the stock ones are too weak for such an application with being lowered and on medium/high stiffness they stock endlinks cant take the agressive angle the endlink is at. If your guna do it do it right, my car is now lowered with zero preload on both my sway bars, where are yours and whoever doesnt have adjustable endlinks will...
You are talking about the endlinks for the 03-04 cars. The 05's and up got revised endlinks that are significantly larger and tougher.
I have Hotchkis sways on an 05 sedan and no issues.
Old Nov 19, 2009 | 07:15 PM
Swivel's Avatar
Moderator
Sways, struts, spring, yes, but don't forget good tires!! They can make a huge difference.
Old Nov 20, 2009 | 10:42 AM
they might be stronger, but regardless there is still preload on your sway bars. 05 revised links are only a bandaid for the real issue.
Old Nov 20, 2009 | 12:03 PM
spankminister's Avatar
Seconded, I'd also like to know, because I'm about to buy a set.
Old Nov 20, 2009 | 12:07 PM
dofu's Avatar
20 Year Member
I'd like to know too... I have them on my sedan and have absolutely no problems with them so far...
Old Nov 20, 2009 | 12:17 PM
Blue Dream's Avatar
Any recommendations on aftermarket endlinks? Do you think they should be changed out now or wait to see if the stock ones give out?
Old Nov 20, 2009 | 02:26 PM
G35fromPA's Avatar
SPL Parts makes excellent adjustable endlinks, though they are pricey:
http://www.splparts.com/main4/index.htm
Old Nov 20, 2009 | 05:01 PM
i have powergrids, i couldnt be happier. The spl links look like u can make them from home depot parts
Old Nov 20, 2009 | 08:05 PM
dofu's Avatar
20 Year Member
Exactly what I was thinking when I first saw them a few years ago!
Old Nov 21, 2009 | 04:35 PM
G35fromPA's Avatar
How's the ride compare to stock shocks - local roads, rough roads, highway? Any high frequency vibrations with them?
Old Nov 23, 2009 | 03:48 AM
DefJukie's Avatar
With JIC coils and adjustable sway bars, I had the sways both set at med and that was perfectly fine like that. Handling was very neutral with just a bit of sway for just the right amount of energy transfer. Playing around with the height and other settings along with other mods, I was able to add oversteer or understeer for preference. And by the time I was done, no matter what the speed, point the wheel and the car follows.
Maybe you guys can help me out with my suspension tuning issues. I started with Cusco sway bars, then got some GT Spec bracing and bars, then finally got some Cusco Zero2 coils and a FSTB.
Up until I got the coilovers, handling kept improving and I could take turns quicker and easier, much better than stock. Then the coilovers went on, only about 1/4 inch lower than stock, and i had no body roll at all but didn't have traction either. Turns I used to take at 50 I could only take at ~42 now before losing traction, though it was very easy to control.
I've tried all kinds of setups with the coilovers and currently, I am running with no sway bars at all, neither Cusco nor stock. This is the best I have found so far and I am taking that turn around 56. From what I am guessing, the front spring is farrr too stiff and thus removing the sways and letting the suspension work independently has helped a lot. What else can I try to help improve this????
Spring rates 560/392
Stiffness settings for the front/rear sways: Front - 120% and 137% stiffer than stock. Rear - 173% stiffer than stock (22 mm).
Old Nov 23, 2009 | 10:01 AM
definitely put your sway bars back on. What kind of tires are you rollin on? If your on stock tires or stock rims, there is your problem
Old Nov 23, 2009 | 10:09 AM
  #30
Swivel's Avatar
Moderator
Not to re-start the age-old SPL vs Powergrid argument, but IMO a heim joint (SPL) is far better/stronger than a threaded cast rod end (Powergrid). I'd worry about it cracking. I will go with the SPLs -- someday when I get the money, LOL!
