good compromise of alignment specs
Old Dec 9, 2009 | 07:40 PM
DefJux921's Avatar
im tired of searching - i've been searching and searching and find so many posts that say one thing or the other. basically here's my alignment sheet. i was going to get camber kit to get it back within spec, but i still want the better handling of negative camber, but also want my tires to last a bit longer.
so the question is, should i put the alignment at the extreme end of the spec? -1.2 up front and -1.9 out back? or should i put it in the middle of the range? or is my alignment not far enough out of spec to even be worth getting a camber kit?
thanks in advance for the help...
Old Dec 10, 2009 | 06:34 PM
Q45tech's Avatar
Remember that published alignment specs are already actual misalignemt specs measured by oem to create xero camber and toe when the vehicle is driving down the road............due to the 25 HP [at 60 mph] pushing the front tires toward the rear.
The suspension is designed to hold the tire as NEAR ZERO CAMBER and TOE as it can.
Static sitting still numbers vs real rolling numbers.
Old Dec 10, 2009 | 07:58 PM
DefJux921's Avatar
so what are you saying? where should i have them put my alignment? should i even bother with a camber kit?
Old Dec 13, 2009 | 02:57 AM
Q45tech's Avatar
The exact mid point of range is the ideal point for tire wear. As the rubber bushings wear, the shoukd be replaced to maintain as near new operation.
Old Dec 13, 2009 | 03:49 PM
DefJux921's Avatar
so in other words, the ichiba camber kit would be fine for me.
thanks
Jusseth
Sep 13, 2020 12:25 PM
hdmark
Apr 29, 2019 04:31 PM
sahizzle110
Jul 29, 2015 11:36 AM
itschuckster
Jul 25, 2015 08:07 AM
