NISMO Suspension S-tune setup with sways for G35 Coupe 07
Old Dec 9, 2009 | 11:56 PM
GTLAW's Avatar
Thumbs up NISMO Suspension S-tune setup with sways for G35 Coupe 07
Hey everyone,
I have search and search, I am unable to find any data or reviews on people with G35 coupe who have the NISMO Suspension S-tune setup with sways.
I currently have 2007 G35 coupe with Premium Package/Aero Package and Sport-Tuned Suspension Package. I don't drive it much so it only has about 2,300 miles on it.
I am starting my project to take the car to the next level up from OEM.
I have been looking at NISMO S-tune setup, I like the fact that I don't have to adjust the car after install and it's all pretune from the NISMO.
But I like to hear from people who have this setup, will the car be lower ? will it get a better ride? will most of the body roll be gone and give me tight ride.
I will also be doing new wheels Rays VR-G2 20inch in the rear and 19inch up front. Also NISMO front bumper with charge speed rear bumper.
But right now I just want to work on the Suspension right now.
Thanks
Please help thanks.
Old Dec 10, 2009 | 03:15 PM
GTLAW's Avatar
wow, I guess there are not a lot of people on this board with this setup.
Old Dec 10, 2009 | 05:15 PM
CreativeDesignZ's Avatar
its a very mild drop, for the money you can buy coil overs that will handle alot better than the s-tune. Your mostly paying for the name
Old Dec 10, 2009 | 08:19 PM
skyline250GT's Avatar
I have Nismo S-tune springs and dampers with stock sways. They were on the car when I bought it so I can't compare it to the stock setup. It is quite comfortable and feels like a "stock" setup to me. It is firm but not rock hard, doesn't crash through bumps and potholes; the movement of the damper and spring feels very controlled. It will lower the car slightly, about 25mm I think.
It does have body roll though, I can't say if its less than stock but coming from a background of running coilovers, it has way too much body roll for me. It is highly likely that aftermarket sways will remedy this and you will have good ride comfort with excellent handling.
Old Dec 11, 2009 | 07:19 PM
GTLAW's Avatar
Thanks for input! I would be doing the complete setup with nismo aways.
I am also looking at KW-3 as well.
Well I need to do Camber Upper A-Arms and rear Toe Control Rod with NISMO setup ?
I am also looking at this setup Kw-3 with CUSCO Sway Bars and CUSCO Negative Camber Upper A-Arm & CUSCO - Toe Control Rod.. With ARC Titanium Strut Bar:
Old Dec 14, 2009 | 09:30 PM
Yes you will need adjustable camber and toe as i am out of spec with the Nismo S-Tune springs.
Old Apr 17, 2010 | 02:19 AM
jonnylaw's Avatar
Do you have s-tune suspension for the Z or the ones for the cpv35? I thought nismo drop is only ~.8 and does not require aftermarket camber arms? I thought that was the point of the nismo suspension (as long as you get the ones specific to your vehicle), that it is non-adjustable and is agressive as you can get in ride height without the need for aftermarket adjustment for alignment?
When I had an alignment done after s-tune install, I was all w/in factory spec except .1 out of range in front. This was with oem 19's though. I'm not sure if I will need camber arms with s-tune suspension and larger and wider Volk wheels/tires...
Old Apr 30, 2010 | 12:48 PM
money042's Avatar
I'm curious about the Nismo suspension on the G, too. Subscribed.
Old May 2, 2010 | 08:05 PM
Sorry guys, I won't be much help here. The car came from Japan with the suspension on it, I dont know if its for the Z or G. Again, with the drop your figures are probably more accurate than mine as I dont have the original setup to compare it to.
My alignment is definetely out of spec though, the shop can get it close but not within factory specs. Mind you, the car has done 102000kms now so the suspension is a getting tired.
Old May 3, 2010 | 06:20 PM
dothemath's Avatar
I see the original post was from five months ago...but...
My installation and review of the JDM S-TUNE G35 suspension...still love it
https://g35driver.com/forums/brakes-...sion-yeah.html
Another review I used to help to decide about my purchase.
https://g35driver.com/forums/brakes-...ine-coupe.html
Old May 3, 2010 | 06:36 PM
money042's Avatar
From what I can gather... there is a Nismo S-Tune suspension. And there is the suspension off the Nismo (edition) 350Z, model year '07 and '08. Is there a difference?
Old May 3, 2010 | 06:49 PM
dothemath's Avatar
What you think is correct is
Old May 3, 2010 | 06:50 PM
dothemath's Avatar
Yes there is a difference...no I don't know what it is though.
rezendvous420
May 31, 2020 01:26 PM
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
laksjd84
Jul 24, 2015 05:12 PM
vstypicals
Jul 20, 2015 10:55 PM
