Just got KWV3, should I install myself or take to dealer?
Old Jan 3, 2010 | 04:25 PM
  #31
Fiddi1's Avatar
Hey do you guys have the torque spec for all the nuts on this DIY?
front upper mounts nuts- 27 ft/lb
front lower shock mount for rear wheel drive sedan - ?
rear upper mounts- ?
rear lower mounts- ?
what else did I miss?
Many thanks!
Old Jan 3, 2010 | 04:38 PM
  #32
AARONHL's Avatar
The two most difficult parts will be removing the front strut and re-bolting the rear lower spring mount. The lower control arm will be in the way of the front strut, so hopefully you will have a heavy person to stand on the wheel hub. The rear lower spring mount might be a little tricky to line up, but using a jack might help.
Old Jan 3, 2010 | 04:45 PM
  #33
AARONHL's Avatar
front upper shock mounts - 26-30 ft/lbs
front lower shock mount - 52-62 ft/lbs
rear upper shock mounts - 20-22 ft/lbs
rear lower shock mount - 74-88 ft/lbs
rear lower spring mounts - 48-59 ft/lbs
Many thanks!
From the factory service manual...
Old Jan 3, 2010 | 09:15 PM
  #34
G35Papa's Avatar
For the front after removing all the bolts (including the end link bolt I recommened earlier in this thread) you push down on the suspension arm which will bring the top strut bolts under the fender well, then pull the strut towards you. Doing so will allow you to push the strut up into the deepest/highest part of the fender well and give you enough clearance to move the lower connection above and around the lower control arm.
Using a floor jack on the rear spring cup will definately make it alot easier to line up the bolt on the front of the spring cup.
Old Jan 3, 2010 | 10:56 PM
  #35
Fiddi1's Avatar
I tried working on the front left shock to begin with. Had to spend some time trying to remove the nut holding the upper arm- it kept turning with the bolt. Had to remove some crusty stuff on the bolt threads and with the use of lithium grease it finally came off after a few tries.
Also had issues removing the lower endlink bolt as an allen key is required to remove it - the bolt head is actually covered. I think for an 05 and 06 sedans, the components used are somewhat different - based on the photos I have seen from the DIY's anyhow. The DIY's certainly helped, but it was kind of frustrating as I thought it would be plain simple. I will work on the right side tomorrow, hopefully it is not going to rain. It think it will be a little easier as I know what things slowed me down.
Old Jan 3, 2010 | 10:58 PM
  #36
Fiddi1's Avatar
how about the lower nut for the front end link?
thanks for the info AARON!
Old Jan 3, 2010 | 11:03 PM
  #37
Fiddi1's Avatar
Removing the end link from the lower suspension arm definitely gave the whole suspension the play I needed to remove the shock.
I just borrowed another jack from my brother so I should be good to tackle the rest, I just need some new cotter pins.
Old Jan 3, 2010 | 11:21 PM
  #38
G35Papa's Avatar
^Good to hear. Every little bit helps getting that sucker out
Old Jan 3, 2010 | 11:23 PM
  #39
OCG35's Avatar
59-70 ft-lb
Old Jan 3, 2010 | 11:36 PM
  #40
Fiddi1's Avatar
Originally Posted by OCG35
59-70 ft-lb
Thanks OCG35!
Old Jan 3, 2010 | 11:48 PM
  #41
Fiddi1's Avatar
I'm just glad you guys are around to help!
Old Jan 3, 2010 | 11:55 PM
  #42
G35Papa's Avatar
Wait till you see the bill!
Old Jan 4, 2010 | 12:06 AM
  #43
Fiddi1's Avatar
Old Jan 4, 2010 | 12:23 AM
  #44
Fiddi1's Avatar
I knew I forgot something...how about the torque spec for the nut on front upper suspension arm with the cotter pin?
Thanks a million!
Old Jan 4, 2010 | 03:53 AM
  #45
G35Papa's Avatar
^I don't know the specs but it's not much. It just needs to be snugged up. Buy the stainless steal cotter pins as opposed to the alluminum ones.
