350z nismo brembo brakes on 05 g35x?
Old Jan 23, 2010 | 12:50 AM
acr's Avatar
acr
Will the brembo calipers/rotors from an 05 350z nismo fit on my 05 g35x? A friend is offering me the brakes from his 350z nismo for my 05 g35x. He installed some variety of BBK.
Old Jan 23, 2010 | 01:19 PM
Tunerz_Store's Avatar
They will bolt right on. You will have to modify the rear dust shield, but that is an easy fix. Just use some tin snips and cut small lines in the dust shield about 1/4-1/2" apart and then use pliers to lift those cut edges up. Make sure you get the rear caliper bolts from the Brembo's, you can re-use your bolts because they are a different thread pitch. The front's are the same.
Old Jan 25, 2010 | 02:10 PM
dubbedown's Avatar
i thought the 05-06 got different brakes which resulted in larger rotors and diff caliper design.
Old Jan 25, 2010 | 11:37 PM
You are correct, excluding the 05 x. But they all still interchange. I ran 05 coupe brakes before I went brembo.
Jiggerjuice
Oct 5, 2015 02:33 PM
Jiggerjuice
Aug 17, 2015 08:41 AM
Popes
Jul 29, 2015 05:07 PM
Karnicle
Jul 23, 2015 05:08 AM
vstypicals
Jul 20, 2015 10:55 PM
