Need Help- Click/Clunk on driveways & uneven roads
Old Jan 24, 2010 | 10:27 PM
Skaterbasist's Avatar
Retired SuperMod
Unhappy Need Help- Click/Clunk on driveways & uneven roads
I need some help/feedback.
As of the last week, I have developed a click that has been driving me insane!
My car is lowered (coilovers), has aftermarket sway bars, rear camber kit, wheel spacers, and has been aligned for the last month.
It started out as a faint click, which has in a matter of about 10 days, turned in to a very loud click/clunk.
It does NOT happen under acceleration or braking. The only time I will hear the noise is when im going up a driveway in an angle or when im driving in a parking lot/street with uneven pavement... and I'm angleling (sp?) in to driveways all the time which makes it a big nuisance
I will never hear the noise at street or highway speeds- only at very low speeds.
I can hear the noise coming from multiple areas (front and rear)- even from the sunroof (I believe this is a separate issue).
The only three things I can think of is:
-My front sway bars need to be lubricated. But I highly doubt sway bars create a "click/clunk" sound.
-My compression rods (bushings) are going bad.
-Axle-click issue, though this doesn't seem the case since this issue is usually associated with acceleration/braking.
I'm hoping this isn't a compression rod issue. I just had my alignment done and will have no choice but to raise the car if I have to bring it in to the dealer.
Any feedback/help would be appreciated.
-Henry
Old Jan 24, 2010 | 10:42 PM
alfhasg35's Avatar
dude... i had the same thing right after i bought new front tires.. took it to the dealer and they thought i had gotten into an accident.. drove me crazy.. i never found out what it was.. all of a sudden.. it just stopped.. it's been like 6mos now and it hasn't come back.. ????
Old Jan 25, 2010 | 12:27 AM
GT-ER's Avatar
I have the same IDENTICAL problem. I too have coilovers and I've had the noise for about 2-3 months already.
Old Jan 31, 2010 | 08:11 PM
Fiddi1's Avatar
I too have the clunking sound after I installed the Ichiba front cambers about a week ago. 2 weeks prior to installing the front camber, I lowered the car with KW variant 3 and had no clunking sound at all. The thing is, it is only on the left side as well.
I actually got the chance to inspect the arm today and it appears that the boot is not sitted correctly. I don't know what to do at this point.
Old Jan 31, 2010 | 08:55 PM
codeflux's Avatar
could be the end-links. check your sways and the end-links.
Old Jan 31, 2010 | 09:34 PM
GT-ER's Avatar
I changed out the endlinks on mine and it wasn't the problem.
Old Jan 31, 2010 | 10:47 PM
Fiddi1's Avatar
My end link was one of my suspects and it looked fine when I checked it.
I am going to try and tighten the top nut for the shock but it's freakin' hard with the
shock on! I don't have a wrench that has a really deep offset to reach the nut.
Old Feb 2, 2010 | 12:26 AM
Fiddi1's Avatar
Anyone have any other suggestions?
Pls -we need help!
Old Feb 7, 2010 | 01:15 AM
Retired SuperMod
It's gotten even worse for me.
Now, I can hear the same deep click/clunk on almost every single thing I do. Uneven pavement while cruising 40mph... click. Driveways... click. On an average 10 mile trip for me, I must hear the same sounds dozens of time.
If I sway the car left to right at any speeds, click.
Old Feb 7, 2010 | 01:22 AM
alfhasg35's Avatar
i thought i read on the forum that it was a bushing on the sway bars... once you take off the sway bar and look at the bushing you will see where it had been clunking.. i dunno.. i swear i came across it on the forum.. i have stillen sways and stock everything else.. it hasn't come back but i bet it will..
Old Feb 7, 2010 | 01:39 AM
Retired SuperMod
The sway bars I have are the Hotchkis V2 with integrated collars. That was a fix for sounds that the V1 had since they had no collars integrated.
Old Feb 16, 2010 | 08:15 PM
Shadowslayer's Avatar
does it make a noise or can you feel it as well, because i just installed a set of coilovers on my car and i have a loud clunking noise coming from the front but i can feel it, its really annoying
Old Feb 16, 2010 | 08:26 PM
GT-ER's Avatar
Do most people with coilovers get a cluck? I ask because I read about it a lot and mine also cluck ( I have H&R Coilovers ) and I can't find the source of the cluck.
Old Feb 16, 2010 | 09:45 PM
Fiddi1's Avatar
On mine, I can feel it slightly tug that something is giving or releasing stress. It makes a sound now when I brake, when I turn sometimes , go in reverse then brake. Ahh, I am going to take the day off this Friday to have a closer look. I may have to go back to stock arms as I did not have the issue before I installed it.
Old Feb 17, 2010 | 01:38 AM
I hope not because whats the point in spending 1000+ on coilovers if all you end up with is a car that sounds as if it is going to fall apart
btw i took my car to the mechanic and he told me he thinks i have a bad strut witch would suck because i bought my coilovers used to try and save some money... well well see how much i really saved in the end
