Sacer and Lowering Spring questions
Old Feb 7, 2010 | 11:52 PM
DOUS's Avatar
Hi There. I'm thinking on buying a 25mm Ichiba v2 spacers to put in my 05 coupe. Has anyone had any problems with them on stock Suspension? Eventually I'd like to put in Tein basic lowering springs also.
1. Does anyone know of any issues with these set up?
2. How much did you pay for yours and what's a good price for them and installation.
A shop was quoting me $360 to lower the car and put in the spacers. I buy the parts. This service includes alignment. Is that a good price?
Thanks!
Old Feb 8, 2010 | 01:06 AM
Xet's Avatar
Xet
I'm dropped on zhtechs and have 25mm spacers all around no rubbing issues or any other issues. I bought my spacers for ~200 for all 4 and the springs used for ~100, I did all the installations myself though. The spacers are as easy as taking off your wheel and putting the spacer on the hub and tightening it then putting the wheel back on. The springs are a bit more intensive, if you are doing coilovers it's easier but if you don't have the tools or time you can have a shop do that.
Old Feb 8, 2010 | 05:38 AM
blackmamba's Avatar
quick question xet are you happy with your 25mms in the rear or do you think going 30mm would look better
Old Feb 8, 2010 | 12:34 PM
eurodre's Avatar
the shop is ripping you off BIG time
the 25mm ichiba v2 spacers to put on is easier than breathing..
take tire off... put spacer on, tighten put tire back on..
and don't do 30mm on stockies it just looks terrible, stick with 25
Old Feb 8, 2010 | 12:43 PM
Higrev's Avatar
That's a lot for installing springs. Highest I think I paid was 100$ adding spacers (like stated above) Easiest thing you can do... Find another shop..
Old Feb 8, 2010 | 12:47 PM
DOUS's Avatar
Even if the $360 (Canadian) includes alignment?
Old Feb 8, 2010 | 01:09 PM
Xet's Avatar
Xet
i would do 30, in fact im starting to look to change my rears to 30. some people say you will have to roll your fenders though, but i dont know for sure until i try.
Old Feb 8, 2010 | 04:07 PM
eurodre's Avatar
thats like 334 USD which is still a lot
i would say the most 100 for spring install and 80 for alignment thats 180.. were are they getting more than double? just walk away man
Old Feb 8, 2010 | 06:51 PM
danielj's Avatar
From: Winnipeg, MB (Biggest/Coldest city in the world)
^^^everything in canada is a rip off man, but by the sound of it 360 is a huge rip off, seeing as some of the other people here got them much cheaper...allignment isn't to expensive and installing springs shouldn't take more then 2 shop hours (or about 150). price should be 250.
putting on spacers is really easy apparently as well. - as long as you have a torque wrench, but its probably cheaper to install yourself even if you have to buy the tool.
Old Feb 9, 2010 | 08:47 AM
A.Chambers's Avatar
I run 30 in the back, on the 350z Eibach Pro kit, stock 18's. I had to roll the rear fenders for the 30's but I didnt have to roll them when I had the 25's on the back.
25 front, 30 rear. Bad Camera phone picture.
Price wise, you are paying to much. If you can change a tire, you can install the spacers. Springs..... not hard, but if you are not sure what you are doing, you can get hurt or break something. $200usd to install springs I would think is reasonable. I got a lifetime alignment from Firestone for $80usd. So any changes I make to the suspension, I run it up there and they realign it.
Old Feb 9, 2010 | 09:38 AM
DOUS's Avatar
here's what another shop (Speedstar) is quoting me on. Taxes in:
Tein S-Tech Spring SKP30-AUB00 F-1.2/R-0.9: $257.70
Tein H-Tech Spring SKP30-BUB00 F-0.6/R-0.3: $270.57
Installation: $150.00
Laser Alignment: $110
H&R DRM 25mm Spacer: $198.75
Old Feb 9, 2010 | 11:14 AM
eurodre's Avatar
^^wtf what is with these shops and charging for spacers? u just fvcking put them on.. dude forget about paying a shop to put ur spacers on
go to different shops one that does install for cheapest and one that does the alignment for cheapest
then get ur springs from vendors here on driver
Old Feb 9, 2010 | 12:29 PM
A.Chambers's Avatar
I think what he is saying was $198.75 is the price of the spacers, not the labor charge. $150 to install the springs is not bad at all. Alignment seems high though. I havent priced these springs but you may want to shop around on them. Most of the time you can find them much cheaper online... and they are springs, not a clutch or anything like that can really fail. They may charge you more labor though.
Also, make sure if they do install your spacers that they know you will be coming back after 50 - 100 miles to have them retorque them.
Old Feb 9, 2010 | 12:47 PM
eurodre's Avatar
^^ah got it thats sounds more logical
and yah the alignment seems high
rezendvous420
May 31, 2020 01:26 PM
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
