Removing caliper bracket
Old Feb 11, 2010 | 05:22 AM
grovefromnh's Avatar
While trying to replace my front rotors, I needed to remove the caliper brackets. Compressor set for 150psi. bolts won't budge! Compressor won't go any higher. How can I get the bolts out? Don't want to apply heat from a torch. any ideas? Thanks
Old Feb 11, 2010 | 09:05 AM
bluemax189's Avatar
are you using an impact???? if so get a bigger one, if not use an impact.
Old Feb 11, 2010 | 01:27 PM
Blue Dream's Avatar
I drove ttrank's car solo
I used a 22mm open ended wrench and a hammer. Soak it overnight in PB blaster as well.
Old Feb 11, 2010 | 01:36 PM
Jeff92se's Avatar
Red Card Crew
1/2" socket and breaker bar + heave.
Old Feb 11, 2010 | 01:38 PM
G35Papa's Avatar
+1 on a bigger impact gun. Trying to get one of those off with a breaker bar is how I hurt my back a year ago. Let the right tool do the work.
Old Feb 11, 2010 | 01:43 PM
goodtwogo's Avatar
IDK if the bolts on those thread in from the front or the back, but if they are from the back, then beware of turning them the wrong way!!
(Don't laugh...it happens )
Old Feb 11, 2010 | 01:47 PM
Jeff92se's Avatar
Red Card Crew
That's what cheater bars are for. I'm not sure if a bigger gun will work when you are limited on the air supply(compressor)?
Old Feb 11, 2010 | 01:54 PM
AARONHL's Avatar
Soak in penetration fluid and bang the breaker bar with a hammer!!!!!
Old Feb 11, 2010 | 02:09 PM
soundmike's Avatar
What's the ID on your hose? I replaced the standard 1/4" with a 3/8" and it's like breathing life into the gun.
Old Feb 11, 2010 | 03:30 PM
brandon1978's Avatar
Other small tricks to get more power out of your impact gun:
You are using impact sockets right?
Any extensions are designed for impact guns?
Every extension loses torque, so use as few as possible
Make sure the socket is straight on the bolt, any deflection will lose torque
And finally, to remove a bolt in the counter-clockwise direction, twist the socket as far clockwise as you can before pulling the trigger.
Old Feb 11, 2010 | 03:33 PM
SxExCx's Avatar
Damn, that sounds hot! lol
Old Feb 11, 2010 | 03:35 PM
AARONHL's Avatar
Ha YEAH it usually turns me on!!!
Old Feb 11, 2010 | 04:32 PM
i've been playing with cars for over 40 yrs. My air wrench is a 1/2 in drive gun type. No extensions used. Compressor set at 150psi, still can't get the top bolt of the bracket to move. I might have to heat the bracket area around the bolt with a torch, but I'm concerned that might weaken the bracket. no room to swing a hammer. this is the driver's side so the wrench/ socket has to go up.
Old Feb 11, 2010 | 04:37 PM
AARONHL's Avatar
Strange you are having problems with this bolt. You could raise the car a little higher to hit the breaker bar from underneath. I think that's how I did it.
Old Feb 12, 2010 | 06:33 AM
I FINALLY got the bottom bolt out late yesterday!!! Top one still won't move.
