Destroyed my compression rod?
Old Feb 12, 2010 | 08:28 PM
Heist.'s Avatar
I know the bushing is gone, but can the rod be salvaged? The other bushing looks fine, just around the bushing it looks slightly more oval then other pictures of them. Has anyone has success with pressing the bushings in? I would rather spend 20$ then 200$ and i have a friend with a press.
Pictures:
Old Feb 12, 2010 | 08:38 PM
GreenGoblin's Avatar
The goblin resurrection
I have a set for 100$
Old Feb 12, 2010 | 08:43 PM
Heist.'s Avatar
I need this fixed by this weekend and don't really want to buy used for this. Thanks though.
Old Feb 14, 2010 | 10:28 PM
OCG35's Avatar
I have a pair of bushings... might be too late - let me know...
and yes, I've had a pair pressed in...
Old Feb 14, 2010 | 10:50 PM
Heist.'s Avatar
what kind of press did you use? was it easy? Also its no too late, but I think im just going to pick up 2 tomorrow and do both sides.
Old Feb 15, 2010 | 12:07 AM
OCG35's Avatar
Temple City Auto has a press... didnt take long... the only snafu is lining up the center of the bushing since the arm/rod is an odd angle... trying to keep it centered between two aluminum blocks and keeping leverage was a challenge... I didnt do it, John did...
but its a lot cheaper than buying entire rod.
The two that I have are used, but perfect condition - low miles... $10 each if you want them... I'm going to Church Automotive in the morning and can meet you on my way if you want.
Old Mar 24, 2010 | 11:31 PM
batanatoly's Avatar
I have same problem (05 G35 Coupe) please anyone. I want to know how you replaced the compression rod. I will be changing them soon.
Do I need to remove the cross arm underneath the compression rod (where the rod is mounted), how do I take it out.
Pictures will be very helpful.
Thank You
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
prinny
Nov 22, 2015 11:07 PM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
yosip1115
16
Sep 28, 2015 04:14 PM
