What are the advantages of adjustable shocks vs none adjustable.
Old Mar 9, 2010 | 06:31 PM
  #31
Jeff92se's Avatar
Red Card Crew
IMHO the problem isn't "preload", it's the valving. OEM shocks aren't valved strong enough to handle a spring that has a rating higher than the oem spring.
The Z shocks just give you another 1" of travel before bottoming out and damaging your shock.
If the valving was okay and you never bottomed out the shock, the oems would be fine.
I don't know the spring rating of the spring you have. If it's near oem, you're fine with the revised Z units. They are so cheap to find used anyway, you an replace them all the time and not have it cost much
Old Mar 9, 2010 | 06:34 PM
  #32
JOKER's Avatar
CLUB MODERATOR
Originally Posted by SwivelHips
NO. LOL! How did you ever buy a whole car??
what you mean?
Old Mar 9, 2010 | 06:35 PM
  #33
JOKER's Avatar
CLUB MODERATOR
G35 Stock spring rates are:
F 314
R 427
350z H-Tech spring rates are:
F 358
R 375
350Z H-Tech are progressive springs. So those numbers do grow once you compress them
Old Mar 9, 2010 | 06:39 PM
  #34
Jeff92se's Avatar
Red Card Crew
Seems like the Z shocks are fine (as already mentioned)
Old Mar 9, 2010 | 06:46 PM
  #35
JOKER's Avatar
CLUB MODERATOR
what makes 350Z shocks better than G35 shocks?
why my shocks were not able to handle these springs and 350 will?
Old Mar 9, 2010 | 07:16 PM
  #36
Jeff92se's Avatar
Red Card Crew
How do you know your oem shocks weren't up to the task?
Old Mar 9, 2010 | 07:58 PM
  #37
JOKER's Avatar
CLUB MODERATOR
cuz they died
Old Mar 9, 2010 | 08:04 PM
  #38
Jeff92se's Avatar
Red Card Crew
Miles?
Old Mar 9, 2010 | 08:08 PM
  #39
JOKER's Avatar
CLUB MODERATOR
Miles?
90k
But I want it to be right for another 90k.
And I don't wanna settle for something that "should work"
I want something that is absolutely right.
Old Mar 9, 2010 | 08:24 PM
  #40
Jeff92se's Avatar
Red Card Crew
90k is good amount of mileage for any shock.
Old Mar 9, 2010 | 08:49 PM
  #41
nghiars's Avatar
The reason why I went with Z shocks is becuase my car is lowered. Which results in my your shocks/struts being compressed more by about 2" on a normal basis. I went with Z shocks/struts that have shorter lengths to accomodate that shortened height.
Old Mar 9, 2010 | 10:07 PM
  #42
JOKER's Avatar
CLUB MODERATOR
well as I have said before my springs are shorter than 350Z oem springs.
So if I go with OEM 350Z shocks they still be compressed more than they should during normal operations.
Old Mar 9, 2010 | 10:48 PM
  #43
Swivel's Avatar
Moderator
what you mean?
So much analysis and indecision over a minor part, how did you ever decide about how to buy something with hundreds of parts? Just yankin' your chain, man, I don't have the perfect shock solution for you. Maybe take some measurements and phone Tokico/other manufacturers?
Old Mar 9, 2010 | 11:16 PM
  #44
JOKER's Avatar
CLUB MODERATOR
yeah, I know I might sound a bit annoying with all this.
I just want what's best for my G.
Old Mar 10, 2010 | 12:55 AM
  #45
Jeff92se's Avatar
Red Card Crew
The only reason to run the Z shocks is for the greater amount of piston travel before it bottoms out!
