for those with tein s techs, question?
Old Feb 24, 2010 | 10:51 PM
Gonpostal619's Avatar
I just installed some s techs, and in the front my passenger is slightly higher than the the drivers side by maybe a half inch. I only had them on for 2 days now. Is anyone else experiencing this? Should I just let them settle first? I made sure the springs were seated on the perch correcty too. Thanks in advance.
Old Feb 24, 2010 | 10:58 PM
jayk's Avatar
Do you mean the REAR PASSENGER? never heard of Fronts being off.
If you do mean the Rear, check out "Springmount Mod" by Redlude.
Old Feb 24, 2010 | 10:59 PM
no the rear is fine, its the front
Old Feb 25, 2010 | 01:26 AM
UltraBlue600RR's Avatar
The only time I heard of the front sitting higher on one side is if the spring was upside down or not seated correctly. Might want to take it apart and check it again.
Old Feb 25, 2010 | 02:27 PM
bjquinnIUmed's Avatar
I'd say give your install the once over to make sure everything was installed properly and that spring is seated the way it should be. Honestly for some reason this appears to be a common problem with tein springs, cuz I've heard of this uneven tein drop complaint a lot. Sometimes it can be a product of the car being on jacks so maybe just give it another few days to settle.
Old Feb 25, 2010 | 02:36 PM
jayk's Avatar
check your strut placement to the engine bay. maybe its not flush.
Old Feb 25, 2010 | 06:22 PM
KT-Lex's Avatar
humm.. Maybe I should check my car to see if I have the same issue.
Old Apr 29, 2010 | 02:46 PM
ffdmk's Avatar
just installed mine two days ago. fronts appear to be equal but rear passenger looks a little higher. how did yours come out after settling?
youngdip631
Lighting
Aug 27, 2015 03:49 PM
zcherub
Aug 27, 2015 09:47 AM
TreeFiddy
Aug 10, 2015 06:50 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
