Camber adjustment question....
Old Feb 28, 2010 | 04:05 PM
eurodre's Avatar
^^yeah i was just looking at that.. that's very interesting good find
Old May 24, 2010 | 06:39 PM
DailyDrivenCoupe's Avatar
hey hotelcrazy how is your car riding since you ordered the ichiba. im in the market for suspension but not putting it on until i have correct camber adjustment cause im not eating up sets of tires. but did you get it aligned after you installed them and what specs are you in now. im also interested in the ichiba's.
Old May 24, 2010 | 09:36 PM
Gsedan35's Avatar
I know the body of this thread is from a few months ago in feb.
But, when you remove negitive camber in the rear, that adjustment effects rear toe. If you've already made a camber and toe adjustment with the oem adjustors you may have already be maxed out on rear toe control. This is why it's a good idea if you buying rear camber arms, you really want to also get elongate toe cam bolts as well.
Old May 25, 2010 | 01:00 AM
xXHotelCrazyXx's Avatar
loving it with no regreats!
Old May 25, 2010 | 08:29 AM
awesome. i like input from people who actually use them. were you able to get pretty close into spec
Old May 25, 2010 | 02:25 PM
as close as i could, but im running a decent aggressive setup slammed on coilovers
Old May 25, 2010 | 02:36 PM
Marks G's Avatar
Which front camber kit did u end up going with hotel ?
also which coilovers do u have ? everything looks good as always
Old May 25, 2010 | 02:41 PM
The Stimulation's Avatar
Originally Posted by xXHotelCrazyXx
SPC is the same is Ichiba, same product different name from what i hear from several people? SPC sells its product under 3 different names?
SPC is the same as Eibach. Ichiba is different from my understanding. Haven't herad Ichiba being the same as SPC, but I could be wrong.
Originally Posted by biggz786786
i would say get spl pro rear and spl fronts
spl pro rear give +/- 10 degrees and comes with toe bolts
while you are getting the rear, might as well get the fronts as a package deal, cause since you will be adjusting rear you might want to adjust your front to match that for even tire ware and better handling, but with that much camber, expect to ware out your tires pretty quick haha
i have to admit tho, your stance and overall style and stance is just pure sex on wheels
I highly doubt you get +/- 10 degrees of adjustment for the rear. That's WAY too wide of a range. I know it states that, in the product description. I think it's more like 5 degrees each way, not 10 degrees each way. It probably has 10 degrees of total adjustment from the center.
Old May 25, 2010 | 04:02 PM
looks great. i will have absolutely no problem with them then cause ur lower then what im going to be. but great pictures as always
Old May 26, 2010 | 12:24 AM
Your right, i stand corrected Thanks for correcting that! Dont want to have misleading info!
Old May 26, 2010 | 08:07 AM
[QUOTE=donpisto;5125341]SPC is the same as Eibach. Ichiba is different from my understanding. Haven't herad Ichiba being the same as SPC, but I could be wrong.
great info on that! was looking at ichiba but definately want something that i can use later when i switch to a coilover setup
Old May 26, 2010 | 11:40 AM
I've heard of some people being able to use the Ichiba to it's said specs, and others that have said they couldn't. I haven't used them myself so I can't really comment. I'm using Battle Version camber and toe arms in the rear (longer, customized ones for additional negative camber) and Cusco up front since I wanted negative camber.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
Fox843
Nov 7, 2015 05:43 PM
