Another Akebono kit spray painted!! pics
Old Feb 27, 2010 | 02:01 PM
migueralliart's Avatar
Hi there fellas I just painted my set of Akebono Brakes. I chose red cause my rims are medium gray so both the rims and calipers silver just wont cut it for me. So here we go I will let them cure for 2 days and then spray the logo with stencils (thinking white LOGO?) and then apply clear to the calipers. Let me know your feedback guys. I used duplicolor high temperature engine paint. Color chrysler red.
Old Feb 27, 2010 | 02:03 PM
Calvin's Avatar
Overglorified Altima
What what your prep process? What kinda of paint did you use?
Old Feb 27, 2010 | 02:09 PM
PAint was duplicolor high heat engine enamel with ceramic. Color chrysler red
Process:
1-Remove the bleeder bolts and cover the inside of the hole with some paper
2-Wet Sanded the clear off the calipers (took about 10mins each caliper)
3-washed with water and dried with a microfiber cloth rest at sunlight for about 10 mins
4-Cover with tape the pistons and seals
5-Pre warmed the calipers with a blower (I live in Puerto RIco so there's a high % of humidity)
6-Applied 3 coats of paint at 10min intervals
7- 1 can of beer some pics, photobucket, G35driver ... you know the rest
Old Feb 27, 2010 | 09:31 PM
soundmike's Avatar
Looks good. So, are you using High Heat, or Engine Enamel? If it's the latter, you'll need 5 days cure time, the clear 7 days.
Here's mine using the same process.
Old Feb 27, 2010 | 09:35 PM
Originally Posted by soundmike
Looks good. So, are you using High Heat, or Engine Enamel? If it's the former, you'll need 5 days cure time, the clear 7 days.
Well I am using engine enamel, I know that the can says 5 days, but honestly I don't think I will need that many days.
Old Feb 27, 2010 | 09:50 PM
soundmike's Avatar
Totally up to you, but just a word of advise, if you're doing just one layer of paint, you're fine. But keep in mind, if that paint doesn't cure/flash properly, the next layer won't adhere correctly and in extreme cases the underlying paint will gas up and ruin the topcoat.
Old Feb 27, 2010 | 09:51 PM
Cool, for two coats of paint 5 days is just too much for me...
Old Feb 27, 2010 | 09:53 PM
TheDude's Avatar
looks good.
Old Feb 27, 2010 | 09:54 PM
soundmike's Avatar
I hear ya, mine took 17 days.
Old Mar 21, 2010 | 03:10 PM
Well guys, just to give you an update here they are finished and cured, install will be during the next week.
Old Mar 21, 2010 | 03:44 PM
4DGS's Avatar
Look sick man, can't wait to see em on the car.
Old Apr 2, 2010 | 07:15 PM
Intalled rears, the car is being worked now installing headers and some other goodies like stillen bars and shocks etc etc, but wanted to share
Old Apr 2, 2010 | 07:25 PM
erklep's Avatar
look awesome!
Old Apr 2, 2010 | 07:58 PM
Locksmith's Avatar
Looks great nice job!
Old Apr 2, 2010 | 08:02 PM
GreenGoblin's Avatar
The goblin resurrection
Looking sick
