Rear Camber Kit Didn't Work.. HELLLPPPP
Old Mar 4, 2010 | 07:33 PM
wreckshop56's Avatar
Ok about 6 months ago i made a thread on here about inner tire wear on my rear tires.. I have 20inch Nitto cant remember the model right off bat but i do have a staggered set. Neways I was told that i defenitaly needed rear camber kits so I ordered the front and rear Iachiba<< most likely spelled wrong>>> kit. Now it's 5 to 6months later with brand new nittos that cost around $640 for 2 rears, the tread is showing again. What can i do now i have the camber kits installed with a alignment and it still did the same thing.
I really dont want to go back to stock, I've had many compliments about the car and really dont want to change it.. But i cant keep dishing out 600 every 5 months.. The front tires show no wear. Ne ideas would be appreciated..
Spaces,springs,shocks,lowering i will consider all just to stop the wear.
Thanks
Old Mar 4, 2010 | 07:36 PM
petesg35's Avatar
Did the rear camber kit come with adjustable toe bolts?
Old Mar 4, 2010 | 07:37 PM
petesg35's Avatar
Sounds like the toe is out of wack
Old Mar 4, 2010 | 08:01 PM
LordFappington's Avatar
If your tires are feathered as if the tire was pointing inward or outward like your feet its definately toe.
Old Mar 4, 2010 | 08:14 PM
GeezNuts's Avatar
I agree with the toe theory -- i had a very similar problem running through 2 sets of brand new rear tires in less than 11,000 miles... my car has RAS so when the camber kit was installed, the original shop did not dremel out the toe bolt area and install the bolts - when i took my car in for an alignment, the shop fixed that issue and i haven't had any issues since.
Old Mar 4, 2010 | 10:41 PM
Thx for all the fast responses... I'm not sure if the kit came with the tie bolts... What shop can I take it to that will align it right.. Firestone.. Other professional shops? Will I need to buy another kit? Basically yall are saying my whole tire isn't touching the pavement? Once again thx for all the fast responses..
Old Mar 4, 2010 | 11:06 PM
gary c's Avatar
All you need are toe bolts which you can buy here on Driver on our MARKETPLACE under vendor suspensions. Find an independent brake/alignment shop in your area and discuss with them your need to have the toe bolts installed. They'll come with instructions that will show where the bolt holes need to be elongated. Upon installation you can get your G aligned and tire worries should be over.... Firestone/Sears/GoodYear/Dealerships....No Way!!
Gary
Old Mar 5, 2010 | 01:49 AM
Footballmania32's Avatar
Gary
^Agreed 110%. My mom took her SUV to Firestone for a simple oil change about a year ago. The tech drained the oil, replaced the filter, and never put oil back in it. My mom, not knowing any better, didn't check and completely blew the engine going down the highway. Firestone took responsibility for it thank god. FIRESTONE = NO GO
Old Mar 5, 2010 | 07:44 AM
Are the toe bolts universal or do I have to matchthem up with my rear cambers? I will buy some today if not too expensive.
Old Mar 5, 2010 | 08:18 AM
Marinelli Motorsports's Avatar
Go to brake check. I think they have those in the Houston area...
Toe bolts aren't that much really. Hit me up if you haven't gotten any yet and I can see if I can get you some at a good price
Also, where did you get the rear camber kit? Ichiba does come with toe bolts...
Old Mar 5, 2010 | 09:20 AM
GeezNuts's Avatar
Sals Autosport can help you out - they know exactly what to do - they did a great job fixing other shops work on my car... i highly recommend them and they may even have the toe bolts at their shop... call them - Sal is the guy i've dealt with 713-462-8500
Old Mar 5, 2010 | 05:59 PM
thx finally someone in houston lol
imma call as soon as i get home
Old Mar 5, 2010 | 06:10 PM
tolyD's Avatar
seems like your toe is off... you might need to get toe adjustable link (toe arm) to correct that. I do have a new set at home that i dont need and it was never installed. i bought it for it like 160+ and i dont need it now. i can sell it to you for a lot less plus free shipping, ill give you a good deal. let me know if you want it.
Old Mar 5, 2010 | 10:33 PM
ok, well after checking ebay i found some SPC toe bolts for sale for $44.00. My question to yall would be does it matter that i have the iachiba rear camber arms and the SPC toe bolt?
also
kricci11
i will be give that shop a call tomorrow morning and check n see if he has the parts and how much for the labor.. 290 is far but nething is worth the drive right now....
on a side note....
what rear tires do yall recommend for now?
Old Mar 6, 2010 | 09:05 AM
EL-EE-ES's Avatar
you can just the toe bolt with any rear camber kit. the bolts are installed on a different arm than the camber arms
