Rotor replacement time
Was there something specific you were looking for in the install? Only 4 bolta need to be removed to replace the rotor, but two of them were a pain in the ****...
I suggest you start buying reselling on the forums then...
ah sorry i just priced it and its 433 dollars with full quality brakes and rotors with the black coating in the middle double drilled and slotted (shipped).
Granted if you forego the black coating in the middle and get the exact same rotor its actually 345 shipped
I dunno though depends on your wheels whether or not almost 100 dollars is worth the middle being black coated
Depends if you're saying the premium rotors or not (adds 90 dollars) to have the fancy black middle. That being said to have the lines (even though our OEM ones are fine and unless theres actually something *wrong* with them theres no need to change) and the fluid included in that price depending on the pads is solid
Hasanbaloch
Feb 29, 2024 08:45 PM
front and back and full pads for that
