G35H-tech & 350Z H-tech?
Old Mar 14, 2010 | 04:28 PM
extremepowderco's Avatar
Heres a pic of my 04 coupe with 20" wheels with a 35 in front and 30 size tire rear! I can't find my answer on here! As of now i have close to a 2 finger gap maybe more like 1 1/2 finger gap. What would the F-R finger gap be with my set up on 350z or g35 h-tech. I like the NF210 but i dont like how the rear looks lower than the front. Im trying to find something with a finger gap or a little less but with an even drop and a nice ride close to stock. Could anyone running about the same set up as me answer my question? Thanks For anyones help
Old Mar 14, 2010 | 05:16 PM
forzaG35's Avatar
There are whole lot of discussions on the lower springs here if you do a search...
G35 h-tech gives you a mild drop(F -0.6, R -0.3) which is the only option don't require a camber kit. Z350 h-tech give you a little bit more of a drop(F-0.8, R-0.6), but you need to get the rear camber kit at least.
Check these out:
https://g35driver.com/forums/brakes-...w-updates.html
https://g35driver.com/forums/picture...ts-see-em.html
Old Mar 14, 2010 | 05:31 PM
Check these out:
Also the NF210 1" F .6 R everyones seems to get it in spec with no camber kit?
Are you running any of these spring NF210 or any H-tech?
I've been on them forums! I know what the drop is so on but they dont tell me crap! The NF210 drop looks way more than it calls for! Nf210 is 1 to .6 and you cant get a finger with 20" wheels on 30 series tires. So before i buy the springs i would like to know what the gap is! Hard to tell the gap in a picture! 17" to 20" is a big diff in gap on diff springs! Thanks Josh
Old Mar 14, 2010 | 07:01 PM
HenryLee's Avatar
350z H-techs all the way. Better spring ratings.
Old Mar 14, 2010 | 07:37 PM
What size wheels and tires are you running? whats your gap?
Old Mar 14, 2010 | 08:25 PM
Tollboothwilley's Avatar
get the 350z h-techs. they are a much better look and the drop looks much better.
I'm on 350z HP shocks and 350Z H-techs.
Old Mar 14, 2010 | 08:39 PM
HenryLee's Avatar
Hey I Pmed you back. These are pictures of 350z H-techs.
Old Apr 18, 2010 | 01:32 PM
Ok go my alignment done today. Ok so lets go over this again I have 350z H-Tech's 20" wheels with a 35F and 30R series tires. I have a hafe finger gap front and a finger or so gap rear. Thats about 1/4 gap front and 1/2+3/4 gap rear. I am a little off on my camber but im in spec on everything else. The camber is real close to spec so im happy with it. I hope this helps people with there setup. People on this board can be so unhelpful when you need it. I was told i would have to to get a camber kit. Yes its true but i am so close to spec in rear it would be a waist uless i wanted more + camber. The front is only a hafe a deg from min spec but i could get the SPC shim kit and be in spec. I rather have the - camber to handle better.
Old Apr 19, 2010 | 02:21 AM
drikx's Avatar
is it just me or does it look like his car is already dropped
Old Apr 19, 2010 | 03:18 AM
Xet's Avatar
Xet
big wheels, look at the clearance from the front bumper to the ground on the first pic, 4x4 status
I would go for the z-htechs I like mine
Old May 17, 2011 | 11:42 AM
Will_Ireally_AM's Avatar
What r ur tire sizes
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
DRG35R
Jan 31, 2016 07:14 AM
