when lowering...
Old Mar 16, 2010 | 03:43 AM
socialconflicts's Avatar
when lowering...
hi all, so i have hopefully a few simple questions for those of you who have lowered their car. i essentially want to get 18s, and was thinking of the Z drop. but i have seen other springs like this for example. its the g37 sport coupe suspension.
http://sandiego.craigslist.org/csd/pts/1637000674.html
how much of a drop difference would that be? from the Z to the coupe drop.. would i have to look into purchasing anything else when i drop it? would Coils be needed? any advice is greatly appreciated.
Old Mar 16, 2010 | 10:00 AM
NjMatteSedan's Avatar
Get tein h techs if you want a moderate drop, nothing is needed except alignment. Coils if you wanna be slammed and adjust the height to your liking
Old Mar 16, 2010 | 11:07 AM
canucklehead's Avatar
go to the TECH section, suspension area. that's your best resource for technical assistance related to suspensions.
Old Mar 16, 2010 | 11:38 AM
kennymo's Avatar
Z springs are going to drop you an inch. And then just get an alignment. Coupe springs will drop you half inch
Old Mar 16, 2010 | 12:16 PM
geew1z's Avatar
with Z springs, is it recommended to replace the shocks on non-sport g's?
Old Mar 16, 2010 | 12:45 PM
^ just on the rear mostly, G coupe or Z struts would do
Old Mar 16, 2010 | 02:17 PM
hmm.. would it be bad if i only replace with the Z springs and then get 18s and alignment? or would i have to focus in buying some extra equipment?
Old Mar 16, 2010 | 02:58 PM
H0TEP's Avatar
I'm going w/ Tanabe DF springs and Tokiko struts for the G Coupe since I believe they would be better suited to support the Sedan's new posture.
Old Mar 16, 2010 | 03:24 PM
nghiars's Avatar
I think what you are asking is how much Z or G springs will drop a Sedan. If so, see below:
1. Coupe springs will drop a SEDAN by about 1/2" in more than advertised for a coupe.
2. The Z springs will drop a coupe about 1/2" more than advertised for a Z.
3. The Z springs will drop a SEDAN about 1" more than advertised for a Z.
NOTE: By the sub-forum you posted in, I assume you own a V35 Sedan. You will want to look at 350Z/G35 coupe springs. IIRC, the springs will be different on a V36(G37) or Z34 (370Z) chasis.
Old Mar 16, 2010 | 03:30 PM
ok, so end result, Z springs end up giving more of a drop from what i just read in another forum.
my final question would be. when i get my 18s (will be oem more than likely) will the drop be enough with current shocks, or would i have to replace shocks since different springs?
Old Mar 16, 2010 | 03:37 PM
Swivel's Avatar
Moderator
I wouldn't pay $300 for G37 coupe springs only...go over to my350z and find some Z springs with shocks for maybe a third of that price. Best to change out the shocks too, since they are made to work with the length and rate of the Z springs.
Old Mar 16, 2010 | 03:42 PM
ahh, nono i wasnt planning on buying those ^^ was just an example my mistake for the confusion.
but you say i should go with z springs + shocks? would that be a overall better combination? and do i have to look at any particular year for the spring/shocks?
Old Mar 16, 2010 | 04:43 PM
Heist.'s Avatar
when converting to z spings/struts its going to be a stiffer ride, but they will work better with each other. As far as a particular year I don't think it differs much... look more at the miles they have, when it comes to struts/springs less miles the better
Old Mar 16, 2010 | 05:27 PM
ahh very true, forgot about miles lol! got catch.
thanks for info, anything else i should look into?
Old Mar 16, 2010 | 05:32 PM
4DGS's Avatar
Buy coils the first time, don't waste your time or money.
Go low the first time, look beside my avatar.
