no dust please
Old Mar 23, 2010 | 03:36 PM
kevin3751's Avatar
no dust please
Im looking to replace my rotors and brake pads on my 2005 sedan. The main thing i am looking for is ones that will produce the LEAST amount of brake dust...is there a specific brand of rotor and brake pads that is known for very little brake dust.. Thanks.
Old Mar 23, 2010 | 03:47 PM
Jeff92se's Avatar
Red Card Crew
You AWD? Because the upgraded oem pads really don't dust at all. And I would never give up brake dist performance for how little the dust reduction would be.
If you are AWD, then yeah, I can understand the request but you still have to give up brake performance in order to get less dust.
Old Mar 23, 2010 | 04:49 PM
kevin3751's Avatar
I forgot to mention I have big chrome wheels so im willing to sacrifice performance for dust. And no i am not AWD
Old Mar 23, 2010 | 06:26 PM
Blue Dream's Avatar
I drove ttrank's car solo
This ^^ makes no sense. You have big azz heavy chrome wheels and you are willing to sacrifice performance?? That doesn't sound like a good plan to me. Are you sure your car has OEM pads, Jeff is right. 05 OEM pads have good stopping power and very little dust. You might have some cheap Pep Boys type pads that were replacements somewhere down the line.
Old Mar 23, 2010 | 06:32 PM
The Stimulation's Avatar
Just hose down the wheels, solves the brake dust problem.
Old Mar 23, 2010 | 11:24 PM
rimshaker's Avatar
Then you should go for metallic based pads. Organic pads are the most dusty, but are the quietest; not much brake squealing.
So like everything else in life.. it's give and take. Depends which is more important to you.... dust or noise.
Old Mar 24, 2010 | 01:20 AM
Tollboothwilley's Avatar
Go with Posi-Quiet Ceramic pads. Very little brake dust. Good pads but they need to be warm before you get on them. If they are cold they suck. After a few stops you are good to go.
Old Mar 24, 2010 | 11:33 AM
athens's Avatar
Perhaps old organic compounds used to be dusty.
Not the newer compounds which use Kevlar and Aramids, along with Copper.
The Centric Posi-Quiet Extended Wears fitted onto Centric Rotors give off only a very opaque dust which is barely noticeable and wipes off easy.
rsingerG35
Accessories
Mar 16, 2016 01:41 PM
nice_camel_toe
18 Inch
Dec 13, 2015 06:17 PM
yosip1115
16
Sep 28, 2015 04:14 PM
junon
Sep 5, 2015 10:40 PM
