05 G35X dropped on coupe springs, alignment specs. Camber kit?
Old Apr 8, 2010 | 02:30 PM
mark1478's Avatar
went to get my tires installed yesterday. 245/40/19s on BBSs 19 x 8.5 38 offset. They did an alignment check and take a look.
before:
Left Front: Camber -0.7 / Toe .06
Right Front Camber -1.5 / Toe .08
Left Rear: Camber -3.1 / Toe .08
Right Front: Camber -2.6 / .22
AFTER ALIGNMENT:
Left Front: Camber -0.7 / Toe .03
Right Front Camber -1.5 / Toe .01
Left Rear: Camber -2.7 / Toe .13
Right Front: Camber -2.5 / Toe .66
Whats strange to me is how the front right camber is so off and left camber went into spec. Rears im assuming def needs a camber kit? Thanks for opinions
Old Apr 8, 2010 | 03:40 PM
saywat?'s Avatar
stock coupe springs made the rears camber that much?
Old Apr 8, 2010 | 04:13 PM
mark1478's Avatar
ya..i guess its alot huh. Stock coupe springs. I was hoping by going with the coupe springs i could avoid camber issues/kits etc. now i might as well buy kit with a lower drop
Old Apr 8, 2010 | 04:15 PM
saywat?'s Avatar
how much did it drop the car? im assuming g37 stock springs?
Old Apr 8, 2010 | 04:28 PM
mark1478's Avatar
no, came from a 04 coupe. dropped it about 1 or 1.5
Old Apr 8, 2010 | 04:40 PM
saywat?'s Avatar
^^wow i didnt kno coupe springs would drop a sedan that much. might need to sell mine. how much u bought it for? and to answer ur question -2 camber is alot
Old Apr 9, 2010 | 12:44 PM
mark1478's Avatar
i got mine used for i think around 100. I believe it took it down like an inch up front, and lik 1 to 1.5 in the rear. The rear was really dramatic..almost looks like the tire is in the car.
Old Apr 11, 2010 | 11:18 PM
money042's Avatar
Looks like your rear toe is a little outta whack as well. You'll need to look into the toe bolt and rear camber kit. It's better to have toe in spec and a little bit of camber than the other way around. Toe off spec will kill your tires, not to mention the car will track funny.
Old Apr 19, 2010 | 09:23 AM
OKStateG35's Avatar
Any pictures of the drop in the front? I'm going to be putting Coupe springs on the front of my X, but went with Sedan Sports in the rear.
What are the stock specs for the front? Are yours within spec?
Old Mar 18, 2014 | 11:33 PM
gthangbby's Avatar
https://g35driver.com/forums/g35-sed...bs-rs-gts.html
Last edited by gthangbby; Mar 18, 2014 at 11:35 PM. Reason: Found post answering question
Old Mar 19, 2014 | 02:04 PM
Gman56's Avatar
Looks GREAT! coupe springs lowered it just right. I have a 05X I want to lower her but not to the point where I have to spend more money to get her right!
Old Mar 19, 2014 | 02:29 PM
drkay's Avatar
The X is about 0.5 inch higher to begin with compared to the non-AWD
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
beevanhuynh
Jul 23, 2015 01:37 AM
Soumilg
Jul 18, 2015 12:33 PM
nascarbuff17
Jul 16, 2015 10:23 AM
