Install rear camber, toe arms, toe bolts, and rotors too!
Old Apr 16, 2011 | 07:51 PM
Blue Dream's Avatar
I drove ttrank's car solo
My rear Ichiba rear arms did the same thing. I was looking at the SPL camber arms since I have several SPL parts but the Wicked Tuning arms look intriguing.
Quick question, I thought the AM toe arms were for people with true style coilovers and replace the spring bucket. Why did you need different toe arms AND toe bolts??
Old Apr 17, 2011 | 09:48 AM
obex26's Avatar
The toe arms allow for even more adjustability I think it was worth spending the extra money. And yes when you go to coil overs some brands do eliminate the bucket usage but you have to pay to replace the arm itself. Other brands of coilovers actually still use the bucket.
Old Apr 17, 2011 | 09:12 PM
toro12's Avatar
20 Year Member
So (3) parts are changed for alignment needs of the rear wheels. I hope you can help me understand the work plan by answering questions?
I will set up shock/ spring as "true coilover".
1) Can you clarify if I use the 'turnbuckle type toe arms' and those pull the radius to straighten the rear wheel; is it still needed to have the toe bolts with elongated slot modification for the 'lower control arm'?
2) Is the elongated slots what allows the lower control arm to radius with the toe arm?
3)Can the stock toe bolts be re-used with the elongated slot mod.?
Great rear suspension info and pics. Thanks for taking the time to pass on the knowledge.
Old Apr 18, 2011 | 02:36 PM
1YoungOwner's Avatar
Originally Posted by Jaygotboost
Im about to install my front and rear Megan camber kit, where the Ichiba failed to help prevent that from happening im coating the rubber inserts with polyshore 80, ill make a write up asap because this prolongs the life of these kits, nice write up bro!
Did you do write up?
Old Apr 19, 2011 | 09:05 PM
Kong35X's Avatar
I have the exact same questions as you.
Old Apr 19, 2011 | 09:50 PM
DogStar's Avatar
You can keep the spring bucket in even if you go to true type coils from what I've seen. Its not mandatory that you replace them iirc.
Old Apr 19, 2011 | 11:21 PM
obex26's Avatar
Ok I have edited a couple of posts to try and answer the last few questions. In post 2 I added more comment. I also did the same in posts 4 and 5 to some of the pictures.
Old May 28, 2012 | 08:34 PM
Mr. Samster's Avatar
do you have any updates on how these are holding up?
Old May 28, 2012 | 11:04 PM
obex26's Avatar
Mr Samster I sold the car last year I wanted more HP so I bought a Camaro SS the kid I sold to put coilovers dropped the car super low and not sure what he's done since. but I know he redid the alignment and I haven't heard from him since he called once about a window motor and since everything is covered under my name I think he is good to go. he may even be on this forum.
rezendvous420
May 31, 2020 01:26 PM
youngdip631
V36 Brakes, Suspension, Wheels & Tires
14
Jul 29, 2015 11:28 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
beevanhuynh
Jul 23, 2015 01:37 AM
