Bagged and have a couple Q's!
Old Apr 22, 2010 | 01:32 PM
CDN_G35's Avatar
Hey guys, I'm going to assume anyone whos reading this is or has been bagged before so I have a couple questions! First off, did you guys leave your fender liners in? Secondly, if you're running the dakota digital unit, what PSI are you running each bag at? I am currently running the UAS upgraded kit and my driving setting is at 25-27 PSI up front and I ride the rears right around 15-17 PSI, what do you guys run at? Any input or info would be helpful because I want to get a feel for what everyone else is doing in comparison Thanks Fellas!
Old Apr 22, 2010 | 01:35 PM
JIle342's Avatar
pics....NOW!
Old Apr 22, 2010 | 01:43 PM
CDN_G35's Avatar
Originally Posted by FRY TWO
pics....NOW!
All I have is a ****ty blackberry teaser for now I need a proper shoot!
Old Apr 22, 2010 | 01:45 PM
JIle342's Avatar
wow, that's sexy!
Old Apr 22, 2010 | 02:06 PM
bag35's Avatar
that looks bad ***! i used to have my g on bags but switched to tein flex suspension cause of a hard lesson learned... just remember that no matter what shops tell you, it is riding on air and never as safe as with regular type suspension. have fun and be safe..
Old Apr 22, 2010 | 02:16 PM
CDN_G35's Avatar
Mind elaborating on that lesson?
Lol
Old Apr 22, 2010 | 04:16 PM
beezy619's Avatar
Damn thats pretty low. Looks sick.
Old Apr 24, 2010 | 07:32 AM
CDN_G35's Avatar
Bump for info
Old Apr 25, 2010 | 11:00 PM
rob40wilson03's Avatar
double bump for info!
Old Apr 25, 2010 | 11:08 PM
GreenGoblin's Avatar
The goblin resurrection
lines can blow out, compressors can die, valves can stick. So imagine driving at 80mph and blowing an airline. Been there done that, not on the G.
Old Apr 26, 2010 | 07:50 AM
CDN_G35's Avatar
Yeh, that sounds sketchy! Hopefully mine will hold up for awhile! I sure wish Shane or waijai would chime in and give us the scoop the b@stards! haha!
Old Apr 26, 2010 | 08:18 AM
A good install is the key to success, running lines where they will not get pinched etc... but anything can happen
Old Apr 27, 2010 | 04:12 PM
Johnnyone's Avatar
subscribe to see what others say about UAS
Old Apr 28, 2010 | 09:22 PM
4DGS's Avatar
What shop did the install on it?
We don't usually pull our fender liners when we bag cars, I've never bagged a G but I wouldn't pull the liner if it's not causing you any problems(is it
Your pressure that your running is pretty solid.
Old Apr 28, 2010 | 09:35 PM
CDN_G35's Avatar
The fender liners just rub a bit over bumps if I have it fairly low (25-27psi) up front! The backs can pretty much go all the way down bc I have weaksauce rims! Fenders are rolled tho so that helps! I can pretty much run the rears at 15psi and I'm good to go! I just figured if I ripped the liner out I could ride a bit lower
