skyline r32 brakes on a G sedan?
Old May 12, 2010 | 12:33 PM
VEEG35.0's Avatar
would r32 brakes work on a g35 sedan my friend has a set thinkin of buying it what do you guys think?
Old May 12, 2010 | 03:48 PM
G35fromPA's Avatar
The R32 brake rotors are the same diameter as '04 stock, though they are 6mm thicker, and the calipers are thicker, so you could see some improved heat handling at the track, but realize that the calipers are made of cast iron (unless they are from an R32 M-Spec), which is heavier than stock. With cast iron calipers and thicker rotors, you'll be adding some unsprung weight. Probably better just to get a set of Brembos from a G35 coupe.
Old May 12, 2010 | 04:28 PM
VEEG35.0's Avatar
thank you very much a lot of help
Old May 12, 2010 | 04:38 PM
idrive_MD's Avatar
unless you're getting them for free, not worth it for the reason provided by G35fromPA
Old Jan 4, 2011 | 11:50 PM
4DGS's Avatar
Hate to bump this;
But does anyone know if they are direct bolt on or would you need custom brackets made?
jsimonk
Dec 22, 2023 03:49 PM
Srinidhi
Aug 7, 2015 03:38 PM
Karnicle
Jul 23, 2015 05:08 AM
tehmoonrulz
Jul 19, 2015 10:44 PM
mushu
Jul 15, 2015 03:55 PM
