SPC rear camber arm install
Old May 13, 2010 | 10:48 AM
05skyline's Avatar
Any good DIY write up for the arms/toe bolt install? How much do you torque those bolts when re-installing with new arms and bolt? Any help is appreciated. Thanks.
Old May 14, 2010 | 01:49 PM
Gsedan35's Avatar
Removal and install is simple.
They go in the same way they come out.
Torgue values are 65lbs-80lbs
When you remove a oem arm, take the time to make the SPL arm the same exact length. Let your alignment shop fool with making real camber changes.
On the inner most bolt and washer, make sure the washer is returned to the same exact point as when you first broke it loose. A couple of sharpe pen marks before you start works pretty good, just match the marks up on reinstall.
teamghost
Jul 28, 2015 04:52 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
beevanhuynh
Jul 23, 2015 01:37 AM
Soumilg
Jul 18, 2015 12:33 PM
