Right front camber?
Old Jun 5, 2010 | 06:10 PM
GAU-8's Avatar
that should be fine period. I have those in the garage right now waiting to correct mine. I lowered on OEM Z suspension a month or so ago.
Old Jun 5, 2010 | 06:24 PM
herrschaft's Avatar
I think you should visit another alignment shop before you buy anything. Having that much negative camber on a stock setup doesn't sound right.
Old Jun 5, 2010 | 11:55 PM
changeover's Avatar
cool, thanks. You have the ichiba's?
I thought it was weird too then I looked at infiniti's specs and it says thats their normal camber and its non adjustable. freaking funky
Old Jun 6, 2010 | 09:38 AM
GAU-8's Avatar
Yah, I have Ichiba front and rear as well as toe bolts waiting to go on. When I lowered on the Z OEM stuff, my camber went out of spec equally on all 4 corners. Rear can be adjusted to within spec, front obviously can't. So I figured get all the parts to not only get it within spec but get it perfect for all corners. Everything I read, SPC is the best to offer for the money. Stillen is hideously expensive. There were a couple names I was advised to steer completely clear of due to their early failure for many people. Ichiba had little to no negative comments I could find. I spent 2 days looking for anything out of the ordinary and found none. There's a vendor on here that sells a package set for $410 for all of it including the rear toe bolts. That should help any alignment shop that's worth going to get your car back in spec.
As mentioned already, you shouldn't be out of spec though if you're still stock. Get a closer inspection by another shop. Tell them you measured out of spec somewhere else. Don't tell them by how much. Let them inspect and tell you what they found. Compare their numbers to what you already have. You might have something bent up front. Previous owner mighta put it in a curb or something and didn't care to correct it. Worse yet, it coulda been in a front end collision and that's the best the shop could straighten it.
Old Jun 6, 2010 | 12:56 PM
changeover's Avatar
Cool man, thanks for the help. The front end had been repainted, you could tell by looking at it but nothing on carfax so I dunno what kind of accident it was.
edit: and the only thing out of spec was the front right camber, which he said that he could not adjust. Like I said earlier Ill spend the money i Dont care I just dont want my tires scalloping after a few thousand miles anymore. The noise is insane.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
cbax
Aug 17, 2015 07:41 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
Soumilg
Jul 18, 2015 12:33 PM
nascarbuff17
Jul 16, 2015 10:23 AM
