Right front camber?
Old Jun 4, 2010 | 01:03 PM
changeover's Avatar
Right front camber?
When I got my alignment done at my mechanic the other day they could not adjust the right front camber. I believe its at -1.5 but they kept the sheet to try and find something to correct this. What can I buy as far as kits to correct this problem? Im almost positive this is what led to my front tires being scalloped. Any help is appreciated!
Old Jun 4, 2010 | 11:01 PM
changeover's Avatar
bump I can really use the help with this guys
Old Jun 4, 2010 | 11:52 PM
Johnnyone's Avatar
Get a front camber kit so that they can get it within specs.
Old Jun 4, 2010 | 11:55 PM
changeover's Avatar
All I needed to hear. Any suggestions for a good cheap one? cheapest one I saw on here was the Ichiba. I dont have tons of money to spend, gotta get this, new tires and body work done so Im gonna be strapped like crazy for cash.
Old Jun 5, 2010 | 12:40 AM
Johnnyone's Avatar
I never had experience with Ichiba but would think it would b ok. I would just research on what ppl say about various brand... I personally like SPC
Old Jun 5, 2010 | 12:54 AM
changeover's Avatar
wayyyyy too much money for the SPC for me haha. thanks for the tips
Old Jun 5, 2010 | 12:55 AM
WhosRich's Avatar
What are you dropped on?
Old Jun 5, 2010 | 12:59 AM
changeover's Avatar
Im not dropped
Old Jun 5, 2010 | 07:13 AM
Blue Dream's Avatar
I drove ttrank's car solo
Ichiba might be fine. The problem with the cheaper kits is the limited amount of positive camber adjustment they offer. Make sure you research this before you buy a specific brand.
Old Jun 5, 2010 | 10:42 AM
changeover's Avatar
Well the ichiba I believe goes to a +3.5...I think, I wouldn't need more than that for a normal alignment right? Im not gonna get dropped or anything like just stock.
Old Jun 5, 2010 | 11:15 AM
Johnnyone's Avatar
If ur not drop I wouldn't think u need a camber ki. I will try another alignment shop and ask for the spec sheet when they get done.
Old Jun 5, 2010 | 12:40 PM
changeover's Avatar
I dunno, these are family friend mechanic's. I cant find the alignment sheet but he said the right front camber was off and if I remember it was at -1.5. He said he cant adjust it correctly cause it was non adjustable, and in order to adjust it you would need a camber kit. There is definitely something wrong with it cause after 5 thousand miles my front tires are scalloped bad. They were new.
Old Jun 5, 2010 | 12:47 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
The ichiba kit definitely does not give you +3.5 camber adjustment. It will give you an added degree of positive camber, so that would put you around -0.5
Old Jun 5, 2010 | 01:05 PM
GAU-8's Avatar
http://www.ichibausa.com/ic35g35caarm.html
Right from their official site. +/- 3 degrees.
Old Jun 5, 2010 | 01:17 PM
changeover's Avatar
That should be good enough to do a "normal" alignment right? All I care about is not having my tires scallop again.
